Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
Thoughts on my alarm?
Old Mar 18, 2008 | 01:18 PM
jimmygardone's Avatar
I read all the posts that I could locate regarding how to disable a faulty alarm. I have a 1992 toyota 4wd sr5 pickup. My alarm system (TDS) has begun to flake out. I located what I think is the brain of the system. It is a rectangular box located under the steering column. There are 4 wires that enter the box on one end. There is also a "screw" style adjustment (for sensitivity, I presume) and a very small red light on one of the longer sides. I would like to remove this system until I can get another installed. All of the posts I have seen talk about 2 wires, but as I mentioned, there's four wires on this one. Any ideas?
Is there a replacement that would wire right in there?
Thanks,
JG
Old Mar 20, 2008 | 07:21 AM
fullmann's Avatar
most alarms will have more than 4 wires, it sounds like you may have found the impact sensor for the alarm. follow those wires farther in and they should plug into the actual alarm.
r3dfish
54
May 16, 2016 10:31 PM
shisha1999
Sep 20, 2015 11:44 AM
Esibnitsud
Jul 30, 2015 08:21 PM
jetspeedz
Jul 13, 2015 09:32 PM
Edionne13
Jul 9, 2015 01:59 PM
