What Toy Tech lift should I get? 1995 4runner
First let me start off by saying hello, I'm new here been lurking around checking out pics and threads, I have a 1995 4runner, manual 5spd, 4wd, completely stock but hoping to change that soon.
I've been looking at lifts all over and found that the toy-tech lifts seem to be what I need, but I don't know which one I should get. My truck is more of a daily driver, I go mudding every now and then but that's it. Also I'm not very knowledgeable about tech talk so keep it simple for me :] thanks
Ok so there is a full OME suspension kit( http://www.toyteclifts.com/index.php...mart&Itemid=72 )
2" lift kit with rear coils( http://www.toyteclifts.com/index.php...mart&Itemid=72 )
And 2" lift kit with rear spacers( http://www.toyteclifts.com/index.php...mart&Itemid=72 )
I don't really understand the difference between the latter 2, would I still have to buy extended shocks if I get one of the 2? And the OME lift has the option of torsion bars, not sure if that's upgraded ones or what.
Any help would be appreciated
Thanks,
Austin
Thanks,
Austin
https://www.yotatech.com/forums/f116...-guide-155339/. Lots of info in this thread...
The OME is pretty expensive. You can piece together a lift and get the same results.
I spent 290 ish bucks and this is what i got:
4 brand new shocks
LC coils
SDORI BJ spacers
extended brake lines
panhard bracket & lspv.
4 brand new shocks
LC coils
SDORI BJ spacers
Thanks for the info guys!
How much lift did you get out of that setup?
I got the heavy duty OME rear springs, their torsion bars, and their shocks all the way around(including the steering stabilizer). I decided against the ball joint spacers because I fealt wierd about cutting the upper control arm. I'm really happy with how my truck rides. I even put right at 1200 lbs of bagged soil in it recently and it handled great with very little sag. But I did spend something like $600 on that stuff. It might have been a little more even.
Ok those links helped a lot and I'm pretty sure what I'm going to get but there are all these other things that are optional like panhard brackets, LPSV, diff drop kit, & sway bar drop kits; I've read what they do and kinda understand but I was wondering like are they necessary? B/C I don't want to be driving down the road and one of my new suspension parts mess up something else
If you get ball joint spacers, regardless you have to cut the control arms. its nothing major and doesn't jeopardize the strength of the control arms.
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
09-04-2015 09:27 AM
Jnkml
07-06-2015 01:20 PM
