What Amsoil grease should I use for my driveshaft ?
Old Feb 3, 2005 | 02:17 PM
pfbmgd's Avatar
I have a 97 runner .I want to grease the driveshafts .I did a search and there is little information on this . I checked my manual and there is nothing there on lubricating the driveshaft .Can someone tell me what Amsoil product to use .Or suggest another quality grease .
Old Feb 3, 2005 | 03:03 PM
TacomaTRD's Avatar
I use their water proof grease, not sure if it's right or not but I have a bunch for my sleds and boats...
Old Feb 3, 2005 | 06:31 PM
Citykid's Avatar
Whadda mean there isn't a lot of info on it???? I had the same problem for my 60k check. I'm at work right now so I can't run to the garage for you but I can tell you I bought two different greases from Amsoil. My ride, a 2001, requires different types. Don't know about yours.
Ckeck out this to get you started. Click here
Old Feb 3, 2005 | 06:58 PM
pfbmgd's Avatar
Sorry I guess I wasn`t clear .There is little information on the type of Lube .I have all the information on how to .
Old Feb 3, 2005 | 07:03 PM
kevin444's Avatar
Use the amsoil grease that work. Or use any NGLI #2 Lithium chassis grease.
Old Feb 3, 2005 | 07:05 PM
kyle_22r's Avatar
any #2 grease should work...marine grease is a good idea if you ever do water crossings or play in mud.
i bought a tube of amsoil waterproof grease for $4 or so at carquest...i figure for how little i really use it'd be a good investment
Old Feb 3, 2005 | 07:29 PM
calrockx's Avatar
marine grease can be used for both the u joint zerks and double cardan zerks? i know there are toyota specified ones, but yeah still...
Old Feb 3, 2005 | 07:33 PM
Bob_98SR5's Avatar
pf,
the type of grease that your vehicle uses is found in the back of your owners manual in a section called "Specifications"
they all differ from vehicle to vehicle (years; some stay the same), so you have to look in your manual.
bob
Old Feb 3, 2005 | 08:10 PM
pfbmgd's Avatar
Originally Posted by Bob_98SR5
pf,
bob
Are the propeller shaft and drive shaft the same ? I only have propeller shaft grease specs (NLGI-2).
Old Feb 3, 2005 | 08:11 PM
Citykid's Avatar
Yes, they are the same.
Old Feb 3, 2005 | 10:25 PM
kyle_22r's Avatar
NLGI-2 covers a LOT of different kinds of greases...it's hard to go wrong here.
Old Apr 28, 2005 | 08:19 PM
gomezza's Avatar
In my owners man. It says "Spiders: Lithium Base Chassis Grease, NLGI No.2" and "Slide yoke and double cardan joint Molybdenum-disulfide lithium base chassis grease, NLGI no.2"
Are these the same thing!??! I mean talk about complex words for GREASE! Can anyone fill me in??
Thanks
Old Apr 28, 2005 | 08:21 PM
Citykid's Avatar
Yeah, there is a difference. I got my two types from Amsoil. I'm just following what Toyota says, others may disagree though.
Old Apr 28, 2005 | 08:29 PM
gomezza's Avatar
whats the difference? and where can I buy the two... which one goes in what?!
Wait... So i've been putting this "synthetic Valvoline grease" In ALL my fittings... did I just distroy my driveshaft!??!? AHH! Am i doing more harm than good... Help!?
Old Apr 29, 2005 | 04:18 AM
gomezza's Avatar
update...
I wrote to Valvoline and they said the synpower will work for both applications. I spoke to a tech at Toyota this morning and he said any warrenty I had on my driveshaft is now void... what the heck! Input anyone?
Old Apr 29, 2005 | 05:20 PM
gomezza's Avatar
bump
bump!
Old Apr 29, 2005 | 07:55 PM
kyle_22r's Avatar
there's a warranty on your driveshaft?
as long as it's #2 grease, you should have no problems. he's full of it.
Old Apr 30, 2005 | 06:08 AM
CynicX's Avatar
hahaha....i watched toyota mechanics use grease....they might as well of been using a big container that said "Brand X Grease" because they dont care, as long as some lube gets in there....
Old Apr 30, 2005 | 02:21 PM
gomezza's Avatar
haha, thats funny! thanks guys... I like this valvoline syn. stuff. Anyone know of a company that has tested amsoil against Mobil 1.
H
Old Apr 30, 2005 | 03:15 PM
mt_goat's Avatar
H
Lots of info here: http://theoildrop.server101.com/cgi/...cgi?category=1
