transfercase noise when passenger is in passenger seat
Old Dec 26, 2009 | 09:22 PM
Austin Marr's Avatar
93' 4x4 pickup with the 3.0liter V-6 3vz-e motor. i have located where the noise is coming from. when someone sits in the passenger seat the floor board touches the top of the transfercase so whenever there is movement from accelerating or braking the floor board flexes and touch's the top of the transfercase creating vibration. its been high centered on the cross member twice. i dont think that its pushed the transfercase up because when i drive with no passenger it makes no noise at all. so how or what can i do to stop it from touching? thanks!
Old Dec 27, 2009 | 05:32 AM
Green_slime's Avatar
you might have tweaked your frame or it could have pushed the case up id actually have to look and see for myself to get a better understanding of how and what to fix
Old Dec 27, 2009 | 07:07 AM
4Crawler's Avatar
Might also check the cab mount bushings on the passenger side. Maybe one or more of them has ripped or had the rubber separate from the steel surround and that lets the cab settle downward with the added passenger weight and that is causing the noise.
Old Dec 27, 2009 | 07:26 AM
bain's Avatar
Mine does the exact same thing.. But my cases have been clocked and tucked up high so I have less than a 1/4 inch of clearance to the floor board.. I was going to put a 1" BL on mine or beat the floor board up a little..If your truck is stock id look under it with someone setting in the passenger side and see how close the floor is to the t-case. Sounds to me like the t-case is twisting more than normal under load..During acceleration the passenger side of the t-case rotates up a tad.. id check the mounts
Old Dec 28, 2009 | 07:09 PM
ok so bad mounts or bushings would have cracks in the rubber? i had a friend sit in the passenger side and it was about an 1/8th or 1/16th of an inch from the t-case. i was thinking about getting a BL too but i dont want to just push the issue aside if its something more then bad mounts or bushings. my rig is stock but i wheel it alot so hopefully all it is, is just worn out bushings.
Old Dec 28, 2009 | 07:19 PM
4Crawler's Avatar
Yes, look for rips where the rubber is torn away from the steel shell:
- http://www.4crawler.com/4x4/ForSale/...l#PolyBushings
Same thing on the t-case and motor mounts.
Old Dec 28, 2009 | 07:20 PM
1989toy4wd's Avatar
Get skinnier friends...LOL sorry couldnt resist
But I am thinking worn out bushings also!
Old Dec 29, 2009 | 10:20 PM
hahaha! that was good one! nice rig!
britishdudes2dr
Jul 25, 2015 06:47 AM
yourrealdad
Jul 21, 2015 11:13 AM
Johntom240
7
Jul 13, 2015 12:18 AM
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
