Tranny + transfer case question...need help!
Old Jan 1, 2009 | 05:13 PM
91Toyota's Avatar
Okay, I bought a tranny and t-case separate. They won't go together because the male end of the transfer case doesn't stick into the female end of the tranny (coupler?) So, basically I have two male ends. Now, I have another tranny in the back of my truck...does the part just slip in and out? I wasn't able to remove the coupler.
Thanks
Old Jan 1, 2009 | 09:57 PM
91Toyota's Avatar
So basically no help?
Old Jan 1, 2009 | 11:15 PM
DeathCougar's Avatar
Got some more pictures of the trans? Mainly i need a view of the shifter plates, and I can tell you exactly why why won't go together.
The coupler does not slip in and out, you likely have a mismatched trans/case. The case is a G-series or R-series case (forward shifting) but I cannot tell on the trans.
To determine if its an R (turbo) or G (Carbbed) case, just count the splines on the input shaft. 21 is Carb, 23 is Turbo.
Old Jan 1, 2009 | 11:24 PM
91Toyota's Avatar
So I basically need a new t-case?
I was told the trans was for a forward shift t-case, and the t-case was a forward shift t-case off of an 84 pickup.
So, just count the splines? Even if I did, two males won't go together...or is that why?
Old Jan 1, 2009 | 11:25 PM
91Toyota's Avatar
Thats all...need more?
Old Jan 1, 2009 | 11:27 PM
Lol not a single picture of the shift plates. Get me a good picture of the TOP of the trans. I see the bellhousing, and the sides of the trans.
Old Jan 2, 2009 | 11:25 AM
91Toyota's Avatar
Went to the dealership and they want $60 for the shaft...I'll pay it but they have 3 part numbers for the same one. And I need a vin number to decipher which one I actually need.
Any help? Thanks DC!
Old Jan 3, 2009 | 01:45 AM
91Toyota's Avatar
Ordered the output shaft yoke. $65 at a dealership...and there is NO return on it. Hopefully it is the right part.
Old Jan 3, 2009 | 02:14 AM
dropzone's Avatar
Fossilized
just needed to post the pictures that DC needed, the part he needs to see is still in the bag in the pics. hopefully you didn't waste $65.
what was the spline count?
http://www.4x4wire.com/toyota/faq/parts/
Old Jan 3, 2009 | 02:24 AM
91Toyota's Avatar
spline count was 21. It has two shift plates too. Definitely a g52 type trans. And, also the diagram that I looked at in two different toyota dealerships were exactly the same, its just a yoke that slips over the output shaft. I'll definitely post pics when I get it.
Bourbonblues
Dec 15, 2017 05:43 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Daenerysdad
Oct 1, 2015 07:33 PM
an1mal_69
Sep 8, 2015 09:40 AM
eggens
Sep 5, 2015 12:16 AM
