tranny problem
Old Nov 15, 2006 | 01:57 PM
smyoder's Avatar
tranny problem
My 5 spd tranny is shifting harder than it used to. It goes into gear really hard. Mainly in 2nd and 3rd gear. Every once in a while it will grind when shifting. I'm thinking warn syncros, but I don't know a whole lot about transmissions. Any ideas?
Old Nov 15, 2006 | 03:39 PM
HAVOC's Avatar
Maybe synchro's. I've seen trucks (mostly Jeeps) that are harder to shift as the temp. drops. The gear oil gets thicker with a drop in temperature.
Old Aug 12, 2008 | 07:55 PM
jason191918's Avatar
If you touch first, then it goes into second easy, or if you touch 4th then it goes into 3rd easy, I would suspect synchros
Old Aug 12, 2008 | 08:01 PM
UCDBunsen's Avatar
Probably is the synchros. Gear oil should only be a problem if you see BIG temperature swings. Nonetheless you should double check that you are topped off and try replacing the fluid. If you see a lot of brass when you replace the fluid it is deffinatly the synchros.
Dieselmann
Feb 19, 2019 02:57 AM
shadowbirdie
Jul 21, 2015 10:38 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
Jnkml
Jul 6, 2015 01:20 PM
