Tow Strap
Old Mar 12, 2008 | 05:55 PM
WSUWESTON's Avatar
Tow Strap
What strap is everyone using? I am looking at a 30' 3" strap. What is your strap of choice?
Old Mar 12, 2008 | 06:02 PM
muddpigg's Avatar
4wd in lakewood had smittybuilt 3"x30' 30,000lbs for under $30 and got a pro comp tree saver at same time.
Old Mar 12, 2008 | 06:17 PM
Osep's Avatar
I have the Expeditionware Recovery Strap (EW3) at https://www.expeditionexchange.com/straps/ which is a 2" wide strap. However, they do have a 3" heavy duty strap as well.
Old Mar 12, 2008 | 06:21 PM
deserttoy84's Avatar
Harbor freight deluxe for 4.99. never fails me
Old Mar 12, 2008 | 06:38 PM
Dare44's Avatar
same here cant beat the price and it hasnt broken yet!!!
Old Mar 12, 2008 | 06:46 PM
sloppy85toy's Avatar
im using marine tie down 4 inch dia.rope.believe it or not its almost like using a bungee.u get to the end and it recoils for an extra pull.it takes up a little room but ive stopped breaking like i did with straps and chain.
Old Mar 12, 2008 | 06:50 PM
Brenjen's Avatar
I found a power co. pole dragging/lifting strap with a killer load rating laying in an easement during the Katrina rebuild work I was doing but I prefer chains for towing, just slap a section of pipe between the vehicles & have at it.
Old Mar 12, 2008 | 07:01 PM
WSUWESTON's Avatar
Sorry, I should have titled it recovery strap
Old Mar 13, 2008 | 06:10 AM
dirtoyboy's Avatar
I have used an ARB snatch strap for years...I also have a couple shorter regular straps.
Read this for some good info on breaking strengths
http://offroadrecovery.zoovy.com/cat...rystrapcomparo
Old Mar 13, 2008 | 07:26 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
no-name brand 30' x 2" (fits in hitch receiver) from 4wp for like $12
Old Mar 13, 2008 | 07:47 AM
Aywilkerson's Avatar
no strap broke both of mine, ended up needing a back hoe. ow I have a lifting hoist from the oil field,
Old Mar 13, 2008 | 08:06 AM
dirtoyboy's Avatar
any opinions on chains?
I dont like them and I dont think they are safe
Old Mar 13, 2008 | 08:08 AM
dropzone's Avatar
Fossilized
I have got assorted straps. My ARB strap is great but new it is very pricey. From going on some organized club runs I would suggest getting a strap with looped ends. Some clubs don't allow the use of chains or the cheapy straps with hooks on the end. Try to get something rated several times the weight of your vehicle. Having a longer and shorter strap makes different recoveries easier...
The strap that mudpigg mentioned sounds like a decent deal...
oh yeah, get yourself a good clevis/shackle/d-ring too
If you have to use a chain--open your hood, might save a windshield and other personal bodily harm
Old Mar 13, 2008 | 08:10 AM
EWAYota's Avatar
Chains are too dangerous. I tossed all my chains, just use straps w/o metal hooks now.
Old Mar 13, 2008 | 08:19 AM
Brenjen's Avatar
Chains are fine, it depends on the bozo hooking them up as to whether it's safe or not.
Old Mar 13, 2008 | 08:24 AM
dirtoyboy's Avatar
also, the bozo's knowledge of chain grades and proper maintenance......
Old Mar 13, 2008 | 08:31 AM
Brenjen's Avatar
lol, well true; a person has to be aware of what someone is hooking up to them. I've seen some guys in my life do some dumb...stuff. I once got dragged in an old charger down the interstate at high speeds by a fellow redneck with a pick up & a bicycle chain. He said, "hey man, would you steer this thing for me so I can move it?" I figured he meant move it like across the lot or something so I said sure.
After the weak link was established he went tearing out of there at a high gallop with me trailing behind, no brakes, no seat, vice grips on the steering shaft & only a cinder block to sit on. I finally got a break when he took an off ramp & one of the front wheels fell off. I got out & told him "good luck man, I'll just walk over to Wiggys place (a friend) & get a ride back from him"
So yeah, it's kind of a two way street LOL
Old Mar 13, 2008 | 08:35 AM
alpine4x4's Avatar
We used a strap to try and pull my truck out of where i rolled it. Wal-mart brand rated at like 28k lbs. Broke it. Hooked up some misc. chains we had at home, yanked it right out. I carry both with me, as dragging a tow strap in rocks/dirt/trees cuts and tears it and weakens it.
Old Mar 15, 2008 | 08:17 PM
Taro's Avatar
I carry at least 2 straps plus a tree saver. I also carry chains, they have their place if used correctly.
I like having multiple straps for a few reasons.
1. They break.
2. Sometimes you need a longer strap so you can connect them. Say pulling someone out from dry/solid ground. And solid ground is 100+ feet away. That was not fun but necessary.
The second strap I carry is a new one that I don't use unless I need to combine them. That way the old one gets beat up first. I have also tied the 2 broken ends together before out of necessity, that works ok in a pinch. A simple knot will hold once the weight of the vehicle pulls it tight
Old Mar 15, 2008 | 08:31 PM
rowdy235's Avatar
I normally run a harbor freight special,
I do run chains, I'm just sure to put a blanket over it, and don't overload it.
