Old Mar 23, 2016, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Exterior Guides
Print Wikipost
Show us your best cheap mods!
Old Feb 28, 2017 | 07:45 PM
  #1161
mtnfreak's Avatar
Originally Posted by maxscott
[img]https://i6.photobucket.com/albums/y219/mtnfreak/SmallTowHooks.jpg
I miss that old 1st Gen.
Old Apr 12, 2017 | 08:19 PM
  #1162
YOTATOY403's Avatar
I welded the front diff on my 91 full time front end and put on factory manual hubs. That made it impossible to turn so I would have to get out and I was always locking and unlocking one hub. So I took the front diff actuator apart and lathed out a recess for a spring. The spring pushes the fork into thenengaged position. and I ran vacuum line and a check valve into the cab and hooked it up to an eaton 18speed shifter. Ran the output side to the release end of the vacuum actuator. If I lose vacuum it will default into locked. Now I can engage the front locker and disengage it with the flip of a switch from the cab
Old Apr 16, 2017 | 10:32 PM
  #1163
Mathew C's Avatar
1999 SR5 Manual - Bull Push Bar - $100 No Pics Available! Sorry
Old Nov 20, 2017 | 08:23 PM
  #1164
Tilikum102602's Avatar
Old Dec 4, 2017 | 05:56 AM
  #1165
2wdTOYota's Avatar
Made a custom rear window that functions as break lights and turn signals.
1017548 642204099169672 n
20140322 210448first failed attempts before I redid the lights on the brake light circuit. I still gotta find decent pics.
added more pics because I pretty much did it all on a budget of nothing.
Old Feb 23, 2018 | 03:44 PM
  #1166
cars-guy's Avatar
Gave myself about 3 hp from just cleaning up the head casting on my 22r. Polishing the exhaust, and port matching the intake. all for low low price of free! Heres a video of how to do it if any of you are interested.
Old Feb 12, 2019 | 08:57 PM
  #1167
Kolton5543's Avatar
Installed some puddle lights today. Found these simple grommet mount leds for like 50¢ a piece on ebay. Drilled a hole in the bottom of the arm rest and soldered the lead to the door light. Works pretty good. Cost about $1
Old Feb 13, 2019 | 08:28 AM
  #1168
stovetop36's Avatar
Holy crap you have door lights? I feel so left out. Wish mine was an SR5. I like the mod. I love lighting.
Old Feb 13, 2019 | 10:55 AM
  #1169
Kolton5543's Avatar
Yeah, no doubt SR5 is where its at. I'm gunna use the same lights for some ground lights too.
Old Feb 13, 2019 | 04:41 PM
  #1170
Scenic WonderRunner's Avatar
I have an LED lighting project for my 1988 4Runner. It's going to be 11 LED spot lights all around my truck.
2 4" driving on the Valance
22" light bar middle of Valance
2 7" on top of bumper angled left and right a little
2 7" slim LED spots under my doors for door and side lights
2 4" at rear sides high watts help with looking for camp spots at night
2 7" slim LED on rear Smittybuilt rear bumper for bright back up lights.
Still deciding on switch panel
Old Feb 13, 2019 | 04:57 PM
  #1171
Kolton5543's Avatar
I used some small push buttons in the original cup holder for my panel. I used some diodes and resistors to make them light dimly with the interior lights and then bright when activated.
Old Feb 13, 2019 | 05:30 PM
  #1172
I don't have that cup holder. Mine is a 1988 4Runner.
I'm thinking about doing a switch panel in the center console pocket just ahead of the arm rest.
Old Feb 14, 2019 | 07:55 AM
  #1173
stovetop36's Avatar
I have done this tarp setup too. Though I do worry about it leaking through where the tarp meets the roof. I haven't figured out a solution.
Old Feb 14, 2019 | 01:36 PM
  #1174
Put rocks under your rear tires to raise up the rear of your truck. The rain water will flow toward the front of your truck.
Old Feb 15, 2019 | 09:11 AM
  #1175
stovetop36's Avatar
Good call. My instinct to to put my head toward the front of the cab so didn't want to be pointed down. I have also used a taro like this between to trucks so we have a place to get dress and stage before hunting in some rough weather. Used a hiking pole to prop up the center.
Old Feb 15, 2019 | 01:07 PM
  #1176
I have another large tarp that I can wrap around those tent poles clear to the side of the truck and wall it off like an enclosed room. And in Winter I use my Coleman catalytic heater in there. Nice and cozy.
Old Feb 15, 2019 | 01:50 PM
  #1177
I have installed the 22 inch light bar.The mounts fit to the existing bolt hole for the Valance. I zip tied the light bar to the truck to make sure it stays on the truck if the bolts get loose bouncing on the trails.
The door light is not bolted on yet. It's going right above the rock bar. And I want it tied into my turn signal for a side light for turning. Like my 1976 El Dorado has.
Rear side lights were easy to mount under the factory stock bumper mount. I have them turned forward slightly. And the wire is zip tied to the frame.
Need to find mounting brakets for the from valance and top bumper lights.
Reverse lights will need a drilled and tapped bracket on the inside of the rear bumper.
All of these light sets (pair) were $25 or less on ebay. 22" light bar was only $25 also (480 watts)
Old Feb 15, 2019 | 01:51 PM
  #1178
My front grill is off because I had to install new headlights.
Old Feb 15, 2019 | 05:21 PM
  #1179
Discombobulated's Avatar
Dude, if I lived by you I would want a ride in that caddy what a wicked boat.
Old Feb 17, 2019 | 11:02 AM
  #1180
I've done a alot of mods to my 3.4 swapped T100. Heres a few of them that could apply to any yota
dual batteries, grounds around motor bay, rubber floor, bucket seats, add on gauges ( voltage gauge) , silicone vaccum hoses. Short ram intake. Big sound system, throttle body coolant bypass, A/C delete. Evap system delete, No muffler, took whole truck apart and cleaned and sanded the entire frame and painted on some rustnolem with a brush and sprayer. ( not expensive but alot of work lol ). Light weight steering wheel. Coated door panels. 4.7 gears, ADD delete, flatbed, Redid entire trucks wiring harness/made alot of it myself/ rewrapped it with electral tape and heat duct conduct, Higher output heater fan, extra storage bags and spaces around cab, ( regular cab) ,
A few of planned mods i have are
Rear 02 piggy back, ceramic clutch, full motor rebulid, steel braided brake lines, lightweight crankshaft pulley, aluminum radiator, total chaos ifs frabication kit. Diamond rear axile, Skid plates, headache rack, roof rack, winch, replace most of the plastic trim with carpet.
