sbc 350 in 4runner overheating
Old Sep 5, 2007 | 08:20 AM
ron2k1's Avatar
Question sbc 350 in 4runner overheating
What have ya`ll done to fix this problem i already have a bigger radiator and trans cooler and im still overheating....what can i do without relocating the radiator to the back??
Old Sep 5, 2007 | 08:24 AM
gilby4runner's Avatar
what type of fan do you have on it? There are a few additives that are out there that are supposed to help but airflow has to be your biggest issue. A little more info would be helpful... Oh.. and welcome to YT
Old Sep 5, 2007 | 08:37 AM
ron2k1's Avatar
i have dual electric fans on the front and they arent doing to much ethier and thanks for the welcome!
Old Sep 5, 2007 | 12:03 PM
Jay351's Avatar
is it overheating at low speeds or high speed?
Old Sep 5, 2007 | 12:12 PM
ron2k1's Avatar
at low speeds it seems to take longer to heat up but high speeds it heats real quick
Old Sep 5, 2007 | 12:15 PM
fastkevman's Avatar
Do not try an additive, such as Water Wetter, they don't work, and yes I was one of the stupid suckers that tried it, save your money.
Make sure your system is properly "burped" and doesn't have any big air pockets trapped in there, sounds dumb but, it makes a difference.
If you are running headers you may want to wrap them, thats a tight engine bay for all the heat that would come off of headers.
Old Sep 5, 2007 | 12:17 PM
fastkevman's Avatar
Almost forgot, make sure your fans are going the right way. I have seen other guys mess that up.
Are they pushing or pulling?
Old Sep 5, 2007 | 12:47 PM
ron2k1's Avatar
they are deff pullin in air and i have burped the system as well and still am nowhere
Old Sep 5, 2007 | 12:50 PM
4banginRunner's Avatar
how new is the thermostat?
Old Sep 5, 2007 | 01:01 PM
ron2k1's Avatar
i don't think it has one but ill be checking that tonite but there is defiantly a flow through the radiator
Old Sep 5, 2007 | 01:09 PM
fastkevman's Avatar
Not to piss you off but, you said the fans were in front, if that means between the grill and the radiator, your fans should be "pushing" and you should be able to feel the airflow on the other side of the radiator.
If the fans are mounted between the radiator and the engine, then they need to be set-up for "pulling".
Sounds like an easy concept but, I have done a lot of drag racing and have helped diagnose lots of cooling problems with fellow racers at the track, you would be surprised at how many guys screw that up!
Old Sep 5, 2007 | 01:15 PM
ron2k1's Avatar
yeah i understand that...but yes they are pulling air in to the radiator and they are between the grill and the radiator
Old Sep 5, 2007 | 01:20 PM
fastkevman's Avatar
I neglected to ask the very most important question.
How long have you had this problem?
Is it recent and at one time it cooled properly or has this always done this since going "Chevota"?
Old Sep 5, 2007 | 01:35 PM
ron2k1's Avatar
i didnt do the swap i bought it from a friend of a friend and it has done it since i had it
Old Sep 5, 2007 | 02:14 PM
fastkevman's Avatar
Start simple and work your way through the entire system.
I suspect it has always had a problem.
I hate to say it but, it can also be an actual engine problem, check your oil for water.
Do a search for threads where guys have done a swap, see what they are running (radiator, fans), you may still be under-sized.
Old Sep 5, 2007 | 04:05 PM
ron2k1's Avatar
thats what im thinking maybe a 4core radiator
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
Rkellerman
Jul 12, 2015 08:42 AM
Avenged
Jul 9, 2015 07:55 AM
