rear discs
Old Jan 27, 2009 | 11:16 AM
Oldmans4x4's Avatar
If you get a chance and get around to the template, that would be awesome, thanks!
As for the rest I will see if I can source it out, 300gt calipers look very similar to that of 300zx, I don't know if they are the same, in terms of caliper bracket spacing and rotor size. They are however much harder to come by. I will see what I can do about sourcing for these parts. Again thank you for your time.
Old Feb 9, 2009 | 09:34 AM
Oldmans4x4's Avatar
Originally Posted by 4runner4ever
I asked my friend which calipers he supplied, he thinks they were from a japanese 3000GT.
The landcruiserrotors I used are from a 90-95 LJ70, part no. 42431 60180 or 42431 60190. I don't think these were sold in the US.
As for the template; I can measure up an old axle I have, but if you use an other brand or type of calipers the template would be useless....
I have no idea if a 300zx backing plate would work. You'll have to measure it up, check drum diameter and depth versus brake shoes etc.
The reason we use supra backing plates is that they are of the same diameter, thickness etc. as from a hilux or landcruiser. They all use identical inners so swapping parts between types and models is easy.
I am having trouble finding the rotors you gave. I wonder if there are any other landcruisers rotors that will work with the supra e-brake? Are all the hats the same length and diameter? Thanks again for your help.
Sep 4, 2015 09:27 AM
kirkrunner
Jul 27, 2015 07:59 PM
SMOD
Jul 27, 2015 01:45 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
