Quick drain oil valves - anybody use one?
Old Apr 12, 2010 | 01:39 PM
pendrag's Avatar
http://www.quickoildrainvalve.com/
Anybody ever use or see one of these quick change oil drain valves? Seems a little gimicky, but not necessarily such a bad idea.
Old Apr 13, 2010 | 09:57 PM
pendrag's Avatar
So nobody, huh? In a very odd coincidence, my dad independently came across these and mounted one on his Tundra the other day. He says he hasn't had any leaks, but he's only had it on there since his most recent oil change (when he mounted it), so he can't yet comment on how useful it is during an oil change. He bought the one with a hose nipple.
Old Apr 13, 2010 | 10:00 PM
874runnersr5's Avatar
haha wow, is it that hard to remove one friggin bolt?
Old Apr 14, 2010 | 04:07 AM
Zuke79's Avatar
I don't have one but I have a friend that put one on his wife's minivan. He says its less messy and he doesn't have to jack up the van to reach and turn the nut.
Old Apr 15, 2010 | 01:01 PM
pendrag's Avatar
Like Zuke said, I don't think the issue is that it's hard to take out the bolt, just that it's a little cleaner. Plus, you don't risk over-torquing the oil pan bolt by accident.
Old Apr 15, 2010 | 01:30 PM
badattitude's Avatar
Another plus is eliminating the possibility of stripping the oil pan threads when you tighten the oil drain nut. I personally have a gentic disorder that causes me to constantly over tighten bolts and nuts.
Does it reduce gound clearance?
Old Apr 15, 2010 | 04:24 PM
Jay351's Avatar
Sounds like a load of crap. Just don't reef down on the drain bolt, it doesnt hold the truck together..
Old Apr 15, 2010 | 04:59 PM
phildelfino's Avatar
I used one for awile on a previous vehicle. Liked it, less messy and easier.
Old Apr 15, 2010 | 05:26 PM
yotaman85's Avatar
I had one on my '86, worked great and came with a tube that stuck to the bottom of the oil pan with a magnet for super clean oil changes. plus it had a clip that held it closed so you didn't snag it on any thing and was also a magnet to catch shavings so you could clean it out every so often. I think i got it from yotagod.com (R.I.P)
Old Apr 16, 2010 | 12:28 PM
surf4runner's Avatar
from the oil pan or the drain pan?
the only thing i remember was that its took longer to drain from the decreased ID.
i also like having a magnetic plug.
Old Apr 16, 2010 | 11:45 PM
wyoming9's Avatar
Red face
If you are the one doing the service they work ok. But if have a dozen people have there hands on it 5 out of 6 will be unable to figure it out .
Then remove the whole unit to drain the oil.
We use these a lot on welders where you just can`t get to the drain plug. Me myself that would be the only reason I would use it.
to each there own
Old Apr 28, 2010 | 07:59 PM
Ron Helmuth's Avatar
wyo 9 proves unusually astute at the issue. Techs just can't seem to figure out gadgets like this and end up just removing them.
For the do it yourselfer it makes a lot of sense but I would not trust one in a trail situation. Fram I believe sold or still sells these and just screwing on the extension hose I stripped it and threw the whole dang thing away.
To each his own, again as stated.
Old Apr 28, 2010 | 08:05 PM
SWPERIC's Avatar
i was gonna do it so i cud attach a hose and pass it thru my skid plate but i still have to remove my oil filter anyway. ya kinda just have to get messy.
Old Dec 28, 2010 | 09:17 AM
Tofer's Avatar
Sponsor
just ordered 3 of them...
one for each of my 4runners plus Ashley's Rav4..
Old Dec 28, 2010 | 09:51 AM
Teuf's Avatar
I have had one for a good 15 years, no issues other than it works every time
Old Dec 28, 2010 | 09:52 AM
Teuf's Avatar
ooops.
Old Dec 28, 2010 | 10:58 AM
flashkl's Avatar
got mine about a year and a half ago, love it. Makes dorm parking lot oil changes a lot less exxon-valdez-y and my IFS keeps stuff from knocking it about. PLUS my IFS lift came with a skidplate that goes between the two tower crossmemebers and with the drain valve with the nozzle I can just attach a length of hose to it and drain my oil without removing that skidplate.
Old Dec 28, 2010 | 11:04 AM
flashkl's Avatar
PS I too have the Fumoto valve but the FRAM sure drain and Dorman EZ drain are alternatives
Old Dec 28, 2010 | 11:21 AM
Ironmike4x4's Avatar
I've seen those a few times in the shop. I actually prefer it, but as others say if someone else is changing the oil they probably won't know what to do with it. The ones I've seen don't leak until you pull the leaver on the valv to drain it. I like how my drain bolt is anyways so I wouldn't put one on mine. Of course I do have a lift to work with though
Old Dec 28, 2010 | 12:19 PM
Resto-noob's Avatar
I put a Fumoto valve on my F250. The truck holds 4 gallons of oil, so my other alternative was to get a new drain pan that could hold all of that, or jack it up so that I could slide in a 5 gallon bucket. Either way I had to deal with dumping the pan or bucket. With this valve, I can slide a piece of hose over the nipple and fill a one gallon bottle at a time, shutting the valve when the bottle is near full. Sweet deal.
