Quick drain oil valves - anybody use one?
Old Dec 28, 2010 | 10:09 PM
SWPERIC's Avatar
how do you all change your filter without making a mess?!
Old Dec 29, 2010 | 09:29 AM
Teuf's Avatar
Stuff a rag under filter then remove quickly.
Old Dec 29, 2010 | 11:03 AM
phildelfino's Avatar
I had one on my 97 Tahoe and loved it. My kit came with a hose to attach to the spout. It is cleaner to use and no digging around in hot oil to find the plug.
Don't know about using one on a trail rig, but now that I'm SAS'ed I could check clearances to see if it'll work.
Old Dec 29, 2010 | 12:24 PM
stepside trd's Avatar
Surprised that no one's mentioned the fact that you no longer have to replace the drain plug gasket, or am I the only one that does that? In any instance, I say, if it makes your life a little easier, then more power to you! Being able to do an oil change without tools sounds worth it to me.
Old Dec 29, 2010 | 12:39 PM
  #25
85gijunk4x4's Avatar
dont forget you dont run the risk of dropping the drain plug in your oil catcher!!!
thats always a pita lol
Old Dec 29, 2010 | 12:55 PM
  #26
Resto-noob's Avatar
My favorite benefit is filling directly into old bottles eliminating the dumping out and cleaning of my old oil pan. I should probably pick one up for a 22R, I only have three of them at the moment...
Old Dec 29, 2010 | 08:36 PM
  #27
SWPERIC's Avatar
im sold. will the nipple version fit under the stock skid plate?
Old Dec 29, 2010 | 08:45 PM
  #28
modlite's Avatar
For some reason, I can just imagine someone coming up and opening the valve on me in a parking lot, and i drive away.
Other then that I like the idea of being able to drain straight into bottles.
Old Dec 29, 2010 | 08:46 PM
  #29
Tofer's Avatar
Sponsor
mine came in the mail today! i'll install the first one this weekend!
Old Jan 6, 2011 | 10:08 AM
  #30
burtoncr's Avatar
I have one on all of my vehicles (5). I love them. Cleaner oil changes and no more stripped oil pans. My subaru has had one for 5+ years with no problems.
Old Jan 12, 2011 | 12:04 PM
  #31
IanB's Avatar
I put a Fumoto valve on the wife's Subaru Legacy, as the oil came gushing out of that thing during oil changes, faster than my drain pan funel could handle and it would overflow onto the garage floor! And that's if you got the drain pan in the right spot in the first place! I've never seen an oilpan drain that fast, not even close. Now I can just run a hose into an empty oil jug, much cleaner and easier.
If your vehicle doesn't have the above problem, then you don't really need a solution IMO, but it's a neat gadget all the same.
Old Jan 12, 2011 | 12:22 PM
  #32
survivorman97's Avatar
This thread also touches on this subject:
https://www.yotatech.com/forums/f2/d...-plate-226290/
Old May 18, 2011 | 02:59 PM
  #33
steverwrx's Avatar
I had one on my WRX for years before I sold it. Great product.
Old May 18, 2011 | 04:21 PM
  #34
mjbskwim's Avatar
If you are doing this for the 'mess' factor,do a remote oil filter under the hood so you just take off a dry filter.
As long as you don't have any jerks around that might open it for you,it seems like a great deal
Old Feb 19, 2017 | 09:32 AM
  #35
Tofer's Avatar
Sponsor
i'm about to install this on my new 3rd gen... you know, over 6 years after ordering it...... any update from anyone on these in the last 6 years? still worth it?
Old Feb 19, 2017 | 09:34 AM
  #36
Tofer's Avatar
Sponsor
looks like the orginial posted website doesnt work any more... heres an updated link https://www.fumotooildrainvalve.com/
Old Feb 19, 2017 | 11:58 AM
  #37
habanero's Avatar
My husband put one on the 99 and likes it. The way he has it installed is a bit tight between the pan and (aftermarket) skid, but he gets to it without having to use me for my scrawny arms.
I'm still old school on the 96, which reminds me I need to change the oil.
Old Feb 19, 2017 | 12:47 PM
  #38
Charchee's Avatar
To each his or her own but I don't have any trouble pulling my plug and I only have to do it a couple times a year. Show me a filter that won't make a mess and I'll be listening.
I worked as a field product support rep for Caterpillar for years and I saw several of these in my travels. Every time I actually saw one I was pointing it out to a customer as the the reason he has a piston rod hanging out the side of his block. Just last month I got called out to look at an overheated log truck. When I got there I found a heater core shutoff valve without the handle on it dripping coolant. Driver said he opened it up because it was cold and said everything was fine for 50 miles. The valve had come apart. No idea why but s*** happens sometimes. Our trucks are off road rigs and stuff gets kicked up under them all the time. Taking your skid pans off makes changing the oil easier too but I'm not ready to throw mine away yet.
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Gamble_STi
Jul 7, 2015 07:54 PM
