Is this pickup worth it?
Old Jan 15, 2020 | 12:45 PM
jjohns2711's Avatar
Still amassing parts for the transplant. Recently did the classic SR5 gauge cluster swap. I have the electronic sensor cluster. Everything worked immediately except the speedometer. Plugged my old one and it worked immediately.
Am I to assume the new cluster I purchased arrived with a faulty speedometer? Do they even break (I’m sure they do, but is it common?) Any input is appreciated. I didn’t even bother to check wiring as my old cluster’s speedometer is still working.
Old Jan 15, 2020 | 01:02 PM
jjohns2711's Avatar
Or would anyone know where to get my speedometer looked at/replaced? I don’t want to look for another cluster but I might have to. What a bummer.
Old Jan 16, 2020 | 08:04 AM
Co_94_PU's Avatar
I'd suggest you start with inspecting what you have on hand.
Identify the SPD signal wire coming out of the harness plug, and locate it's corresponding tab on the cluster. Does it have a good connection?
Follow the copper trace on the flexible circuit board. Is it scratched thru anywhere? Are the screws that connect the flex board to the guage clean and tight?
Next would be disassembly of the cluster to.get hands on the speedometer. Looking for a broken wire in the coil whuch might be repairable with a dab of solder. I don't recall off hand if that one is just a bimetal spring or coil like a solenoid.
Old Jan 18, 2020 | 06:19 PM
jjohns2711's Avatar
I ended up purchasing a different cluster. This new one doesn’t have any issues and works great! Man I love the new dash. Really makes the truck feel sharp.
NEKExplorer
Sep 22, 2016 06:25 PM
little_red_ky_yota
Oct 9, 2011 07:25 PM
Innocent Fool
9
Jun 10, 2009 08:56 AM
tulsa_97SR5
Dec 24, 2005 10:43 PM
Mudd Runna
Jul 22, 2003 06:50 PM
