PCV Oil Catch Can
Old Mar 20, 2010 | 01:32 AM
NwRunner's Avatar
PCV Oil Catch Can
Does anyone use an oil Seperator or PCV catch can on their rig? Its supposed to catch all the oil that blows through the PCV valve and trap it before it enters the intake manifold and get burned up in your engine. Just wondering what people have heard about these, my buddy runs one on his H22 Accord.
Old Mar 20, 2010 | 09:07 AM
mt_goat's Avatar
Yeah I put one on my 5VZFE, I guess my 01 engine is still too new (<40k miles) because I don't get much of anything in it. I've never had to empty it. Mine is on the back line that dumps before the throttle body, that was the one I was concerned about.
Old Mar 20, 2010 | 09:36 AM
kiyobrown's Avatar
Hmm, interesting. Never even thought about it, honestly.
Old Mar 20, 2010 | 09:43 AM
yotarob2005's Avatar
Here is a pic of the one I have on my 05 Tacoma 4.0. It is billet 6061 aluminuim made bt Accurate Machine Works & IIRC it cost around $130. Works very well, I dump it at every oil change (5K miles) and it is uaually about 1/2 way full. It is my opinoin & not a fact that the home made water seperators don't work. Here is a link to the Manufacturer. http://www.accmachtech.com/catchcans.asp
Old Mar 21, 2010 | 10:37 AM
mt_goat's Avatar
Interesting, that's a nice one for sure. You have many miles on that engine?
I guess I'll find out the first time I remove the intake tube and look at the throttle plate. I have seen some guys that get a lot in their home made catch cans, but they may have had a blow-by problem or something.
Old Mar 21, 2010 | 04:05 PM
50K miles on my truck, but I put the can on it shortly after I bought the truck new. All engine's have some blow by, not just worn out ones. Mine hooks up in line between the pcv valve & intake.
Old Mar 22, 2010 | 06:41 AM
mt_goat's Avatar
.. All engine's have some blow by, not just worn out ones. Mine hooks up in line between the pcv valve & intake.
I guess so, but not all blow by is a blow by "problem" Yeah mine too. So you didn't care about the other valve cover vent either?
Old Mar 22, 2010 | 07:02 AM
hross14's Avatar
I have an old jaguar and i use a couple glass fuel filters..works pretty well--or i may just have a crap load of blow by?? either way it is behind the venturi bridge and just gets washed down by the A/F mixture
IDK--i think it maybe a hybrid 2/4 stroke engine but it leaks so much i cant tell where the oil is going
Old Mar 22, 2010 | 07:10 AM
It is my understanding that it never makes it that far, I'm catching it stait out of the PCV valve so it takes the other vent out of the equasion.
Old Mar 22, 2010 | 08:11 AM
mt_goat's Avatar
Yeah I really don't understand the system, for all I know one side is positive (crank case ventilation) and one side is negative.
All I knew was the other one was connected up on the other side (down stream) of the throttle body and I have water/meth injection that will clean out anything dumped in after the thottle body.
Old Apr 11, 2010 | 10:25 PM
NwRunner's Avatar
Just did mine, not sure why there is condensation in it....
Couldnt fine anywhere but here to mount it so ive got a hood snake until i can get a 90* elbow
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
smiley52
Jul 11, 2015 05:16 AM
