View Poll Results: Drop or lift?
Drop
10
55.56%
Lift
44.44%
Voters: 18. You may not vote on this poll
Panhard bracket: drop or lift?
Old Aug 9, 2004 | 11:24 PM
Praufet's Avatar
Which is generally viewed as better dropping the bracket or lifting it. I'm looking at getting so lc rear coils so this would probably be needed.
Old Aug 10, 2004 | 01:06 AM
EWAYota's Avatar
what is the panhard bracket? anyone have a pic of it?
Old Aug 10, 2004 | 02:30 AM
ldivinag's Avatar
if you are gonna make it youself, LIFT.
otherwise, only all pro HAD one... dont know if they still sell it. everything else is drop...
Old Aug 10, 2004 | 07:45 AM
Praufet's Avatar
all the drop brackets I've seen look like they change the geometry of the bar and give it more room to pivot
Old Aug 10, 2004 | 09:17 AM
midiwall's Avatar
Steve Schaefer has a bit of info online - and makes the brackets for resale: http://fastq.com/~sschaefer/store.html#DropBar
Old Aug 10, 2004 | 09:30 AM
Praufet's Avatar
I need one for the second gen though.
Old Aug 10, 2004 | 09:33 AM
midiwall's Avatar
Whoops... I should have checked your sig. Well, the concept is the same for those that are asking about that angle.
"angle".. heh. I crank me up.
Old Aug 10, 2004 | 01:15 PM
weldpro's Avatar
Ask Steve he should be able to make you one!
Richard
Oh, and both will work!
Old Aug 10, 2004 | 01:28 PM
sschaefer3's Avatar
The only 2 places that offer a 2nd Gen drop bracket are Downey and ProComp.
Downey has a 3" and ProComp has a 4". The Downey one is included in a kit that is around $150. The ProComp I'm told is $36.00, but 4", too long.
What I think you "could" do is drill a hole at 2.5" or 3" on the ProComp bracket.
We could also make you a drop bar, but that is $142.00 plus you ship us your bar for the work sonce we don't have 2nd gen cores.
Old Aug 11, 2004 | 06:49 PM
914runner's Avatar
Hey schaefer, when you get your 2nd gen. frame will you be making panhard drop brackets for us?
Thanks
Old Aug 11, 2004 | 06:55 PM
sschaefer3's Avatar
Thanks
I can't do it from the frame but I could do it from Epic Ed's 2nd Gen durring his (September/October) rear bumper build or from the Cheese's 2nd Gen when I see him in Moab.
It's very possible, 2nd Gen is more likely than 4th at this point.
Old Aug 12, 2004 | 01:31 AM
Praufet's Avatar
yay! schaefer built!
Old Aug 12, 2004 | 03:44 PM
Goldrunner's Avatar
I've been trying to get one from Procomp for 5 weeks now, they still say it will be another 3-4 weeks. There on "backorder".
Old Aug 12, 2004 | 05:13 PM
anthony1's Avatar
I'll vote for lifting the axle side. I've bent mine comming down on a rock when I had the 3" drop.
Old Aug 12, 2004 | 06:15 PM
sschaefer3's Avatar
Great! figure out how to do that. In the mean time, we're going to make 2nd Gen drop bars.
100% bolt on and extremely strong. Keep is simple and easy………………
Old Aug 12, 2004 | 06:40 PM
914runner's Avatar
Have you made cheese a drop bar schaefer?
Thanks
Old Aug 12, 2004 | 06:59 PM
sschaefer3's Avatar
Thanks
Cheese has a Downey, he's set.
Old Aug 12, 2004 | 07:22 PM
Goldrunner's Avatar
Steve, what does the drop bar consist of? depending on whether procomp ever comes through maybe I should just cut my losses and go with the drop bar.
Old Aug 12, 2004 | 07:37 PM
sschaefer3's Avatar
You send us your bar, we cut the ends off and re-sleeve the center with a 2.5" drop.
We send it back, we re-use what you already own to save on the cost.
Bolts into stock bracketry, the bar drops.
Old Aug 12, 2004 | 08:05 PM
yotafool's Avatar
i have a 4" superlift drop bracket and i've already broke it.
