Okay everyone let's see some pics of your system...
Old Feb 19, 2009 | 03:21 PM
  #41
algranger's Avatar
Actually i built the box within specs for that particular sub these are the sealed box dimensions reccomended from that sub
"Min Rec Sealed Box Volume (CU. FT., Liters) 2.25, 63.7
Max Rec Sealed Box Volume (CU. FT., Liters) 5.0, 141.6"
Built close to 3 cu. feet so maybe do some research before you say my system is ghetto it's the best one ive ever seen or heard of in an 84 pickup.
Edit: it's wide but only 9" at the top and 11" at the bottom
Old Feb 19, 2009 | 03:24 PM
  #42
tc's Avatar
tc
Check your math - judging from 10's on the top, a 12 on the front and ~48" wide, you're closer to 4 cuft (admittedly, within JBL's barn door size specs)
I had 2 10's in the same space - only difference was mine was an '89 (pix in post 23)
Old Feb 19, 2009 | 03:29 PM
  #43
algranger's Avatar
Maybe it was more than 3 i dont remember but it definitely wasnt's over 5
btw, ported are generally a lot smaller if i put square ports on the sides it would be sufficient for two 12's but i like the deep sound the large sealed box gives you and dont need two subs.. i'm not into pumpin massive bass or anything
Old Feb 19, 2009 | 04:05 PM
  #44
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Since when are ported boxes smaller?
Old Feb 19, 2009 | 04:15 PM
  #45
jpmountainboy's Avatar
Im rockin' the stock tape deck with some old GnR. oh ya.
Old Feb 19, 2009 | 04:16 PM
  #46
but nobody wants to steal it now.
Old Feb 19, 2009 | 06:36 PM
  #47
tc's Avatar
tc
x2 - you have to subtract out any volume the port displaces if it's inside the box
Old Feb 19, 2009 | 06:43 PM
  #48
elblako91's Avatar
1 15" fi btl sub woofer
3000 watts RMS
67 lbs.
Dual 2 ohm voice coils
Magnet is around eleven and a half inches in diameter.
Cost around $450 Smackaroos
And 0/1 Gauge wiring.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600.
Old Feb 19, 2009 | 06:47 PM
  #49
algranger's Avatar
i was reading that the max size for a sealed box is a lot bigger than for a ported box
Old Feb 20, 2009 | 08:57 AM
  #50
toylocost's Avatar
I dont think so Tim...
This is a direct quote from the User Manual for your JBL Sub (if its the GT5-12)...
"An optimum vented enclosure is always larger than the optimum sealed box for the same woofer and will require more space inside the vehicle."
Here is the link to the manual it is on page 2.
The specs JBL recommends for the GT5-12 are...
Sealed: 1 ft^3
Vented: 1.75 ft^3
Bandpass: 2.25 ft^3 (all together)
Old Feb 20, 2009 | 09:12 AM
  #51
toylocost's Avatar
I thought your enclosure looked a little big for the sub. You might want to check it. If it is to big you can damage the sub. Not enough pressure and it will move to far.
Old Feb 25, 2009 | 06:21 AM
  #52
bad@$$4runner's Avatar
i got a rockford t1500 amp and 4, yes 4 15" sony xplod subs in a custom non ported box. double-dynamat throughout. i dont think i can have babies anymore though...
4.34runner88
Feb 7, 2016 02:24 AM
Obmi
Nov 24, 2015 11:37 AM
user 82300
Sep 17, 2015 10:41 AM
HiLuxer
Sep 9, 2015 02:43 PM
