No a/c at idle.
Old Jun 27, 2013 | 07:42 PM
annistonfire153's Avatar
No a/c at idle.
My a/c blows hot at idle. Going down the road it's cold. At idle the compressor doesn't engage but if i bump the throttle a little the compressor kicks on and the air blows cold. The shop says the freon level and pressures are fine. I have recently cleaned the throttle body and replaced the IAC and replaced the TPS. Any suggestions? Please help, it's hot in Alabama.
Old Jun 27, 2013 | 08:13 PM
Stetson_md's Avatar
Never had a/c in a yota but the pulley might be loose or something inside the compressor
Old Jun 27, 2013 | 10:03 PM
ToyX2's Avatar
On the early toyotas (i dont know what you have) there is something you can adjust behind the glove box to the left that shuts off the ac under a certain rpm. I have never done it, only read about it it but it sounds like you can adjust it till the ac kicks on at idle. The idle up valve(?) should also be set so that your idle bumps up a little when the ac is on.
Old Jun 27, 2013 | 11:23 PM
wyoming9's Avatar
Red face
It could be a electrical problem.
At idle the voltage going to the clutch might be just a little low to pull the clutch in. Step up the idle voltage goes up enough to make it work.
Be nice to know just what year your working on here.
Old Jun 28, 2013 | 10:49 AM
My truck does not have the ac idle up valve. But idle has increased with the new IAC on and I still have the problem. But if I bump the throttle the compressor kicks on. Idle =no compressor. Could it be the TPS adjusent, air gap on the compressor, ? I'm at a loss guys.
Old Jun 28, 2013 | 11:37 AM
wyoming9's Avatar
Red face
Maybe you have a loose or corroded connection at one of the pressure switches
.Although who ever checked the pressures should have caught any problems
When you hit the throttle it moves the engine enough to make contact.
No matter what year and engine unless it has been removed you have something that increases the idle when the AC is on!!
If you have had this removed or it was when you bought the truck this might be your problem.
Have you checked the voltage at the compressor??
When it is pulled in ??
Then when it is not?/ if your charging system does not put out enough voltage at idle .
Could be due to poor connections old age who knows.
Compare the 2
If the system is working correct and charged correct it is a electrical problem.
Is the belt tight ??
Old Jun 28, 2013 | 12:13 PM
Thanks Wyoming. I'll check this weekend on your suggestions. I've been told that the idle up is controlled by the computer on mine. And I've double checked and don't see an idle up valve and pulled the glove box and didn't see an ac amp.
Old Jun 29, 2013 | 12:20 AM
Punchy's Avatar
The rpm sensor is behind the glovebox, I have seen two different kinds between the 4R and pickup, One is high on top the unit and the other is on the face of the unit.
the idle up is in the engine compartment on the passenger fender, Usually the grey VSV.
Old Jun 29, 2013 | 05:53 AM
Any pics of this VSV? And when I pulled my glove box all I saw was the big black sealed unit. I didn't see the "black cigarrette box" I've read about.
Old Jun 29, 2013 | 08:20 AM
aztoyman's Avatar
What year truck and engine do you have?
22RE's have the little knob on the A/C amplifier behind the glove box. It adjusts the RPM your clutch will kick in at.
They also have the idle up valve on the intake plenum with a knob that sets your idle RPM once the clutch does kick in so you don't lug your engine at idle.
If it is a 3.0 or anything else I don't know.
Old Jun 29, 2013 | 03:27 PM
2001 double cab with 3.4 automatic.
Chicken12
Oct 14, 2015 03:54 PM
Badlander
Oct 10, 2015 08:05 PM
creecher10
Sep 30, 2015 03:27 PM
bryan34w
12
Sep 30, 2015 02:50 PM
Shagool22
Sep 28, 2015 07:53 PM
