Never Heard of CV Break
Old Jun 10, 2008 | 07:52 AM
4Runner202020's Avatar
So i was wheelin on sunday and i lost power to my front wheels and only my rear were spinnin. Everyone i was with said broken cv but all the boots and visible parts looked good. Then axleike said maybe vacume lines and all those looked ok too. Then i realized gear oil was drippin from my driverside cv connection and the cv was popped out a little not giving it a good seal anymore lettin oil leak so i hammered it back in and thought it was good to go but i still didn't get power to the front tires... So one of my buddies and i went to change my cv yesterday and got it out and realized that the 3in section of the cv that goes intl the housing clean broke in half. that is in solid steal that broke in half!!! so there was still a 1.5in piece of the axle in the diff still while the rest came out. i had never heard of this before and it is going to be a pain to get out!!! i was told by some to drop the diff to get it out and by the mechanic where i work that i can open the housing and try and pop it out that way without dropping the diff. the thing that makes this so hard to get out is that the c-clip is still in place at the end of the axle which whoever of you know that has changed you own cv before that it is a pain to get in let alone get out so i will with the help of other try and get this out. sorry i didn't get any pics of it but on sunday i will and post them up here.
bobby
Old Jun 10, 2008 | 08:01 AM
neoworm0's Avatar
That sucks. Good luck with that. You may have never heard of it but they break all the time.
Old Jun 10, 2008 | 08:03 AM
ya i know they break lol i have changed 5 or 6. haha but in that spot is what i have never heard of. it seems like it would be secure and supported in the housing of the diff dont ya think...
Old Jun 10, 2008 | 08:35 AM
apalmer1's Avatar
yeah CV break happens to just about everybody with IFS. im amazed that i havent broken one yet, but im sure one of them will die eventually. they are $60 at napa, if you have a place anywhere near you that does cryo-treating have them cryo the new CV's ive heard it will increase the durability substantially. im pretty impressed with my taco's stock CV axles as far as what they have been through people will still rip on them and cry SAS SAS SAS but unless you go to at least a dana 44 or a first gen axle with longfields im pretty sure you dont gain much in durability.
Old Jun 10, 2008 | 09:04 AM
dirtoyboy's Avatar
Wheres the carnage pics?
Old Jun 10, 2008 | 10:15 AM
neoworm0's Avatar
you'd think, but I have seen at least one other break in the same place.
I disagree. True, stock birfs are just as prone to breaking as CV's but at least with the solid axle you aren't replacing boots every 6 mos and gettng an alignment after every wheeling trip.
Old Jun 10, 2008 | 11:26 AM
olharleyman's Avatar
Why not try welding a rod on the end and get a body slide hammer and attach it like pulling body damage see if that will work to get it out just a thought
Old Jun 10, 2008 | 12:05 PM
AxleIke's Avatar
Gonna be really hard to weld to that, there isn't much clearance to get in with the welder, and the welds aren't going get great penetration. But its a possibility.
The issue, as I posted on UY, is that you likely have chunks of axle in the diff. They may be big enough that they won't come out the drain plug. Those will eventually chew up your gears. If it were me, I'd pull the diff and clean it out.
Old Jun 10, 2008 | 02:27 PM
tc's Avatar
tc
I have heard of this happening several times ... as a matter of fact, when AxleIke called me after this run, it was my first guess.
I have heard of three successful methods of extraction:
- drill and tap to get a bolt in it
Obviously keeping things square enough for the bolt to actually thread is TOUGH.
- weld
The problem with welding is the arc could go just about anywhere and you don't KNOW that you will be hitting the end of the axle for sure.
- pound it out from the other side
Take off the other CV and using a long rod, beat it out from the other side. Be careful you don't hammer away on the cross pin!
ashamsuddin
17
Jul 22, 2024 03:59 AM
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Oct 2, 2015 07:47 AM
creecher10
Sep 30, 2015 03:27 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
