Need Satellite radio help pronto
Old Mar 11, 2008 | 01:03 AM
stormin94's Avatar
Hey, I just picked up a new "brain" for my XM ready pioneer head unit. The "brain" is basically the tuner that recieves the XM signal for those of you that don't know what the brain is. Anyway, I need advise on where to mount the antenna, and where you guys did.
Where should I mount the antenna, and how do I route it there?
Where did you mount your "brain"?
Also, be sure to let me know what kind of rig you installed it in. Mine is a 1994 4Runner. And if tou have Sirius, that's cool, too, because a satellite radio antenna is a satellite radio antenna. All ideas are welcome.
I'm planning on installing this later today, so the quicker the responses come, the better for all of us.
And I say better for all of us, because if I don't get many responses, and I mount it, and it looks like crap, you will all have to look at it.
Thanks.
Old Mar 11, 2008 | 01:12 AM
Elton's Avatar
ive remember seeing someone here mount theres to that black trim piece next the wiper blades then run it through a hole in the firewall
Old Mar 11, 2008 | 01:20 AM
stormin94's Avatar
That's an interesting idea, I'm wondering how the heck I'm going to mount the antenna on the roof. I'm trying to figure how to mount it through the back somehow, without drilling through the roof...if that is possible to avoid. The rear of the roof seems to give the best signal. I have the roll up window, and I'm wondering if there is a way to route the antenna cord through the rear window(the top part).
Old Mar 11, 2008 | 04:19 AM
bigt's Avatar
o stuck mine on the roof.. its a magnet
Old Mar 11, 2008 | 05:56 AM
Astralplane's Avatar
Here's mine. 1994 4Runner
https://www.yotatech.com/forums/f96/...antenna-74755/
Old Mar 11, 2008 | 12:30 PM
stormin94's Avatar
Originally Posted by Astralplane
Nice job. I knew there was a way to do that. Did you have to take that plastic piece around the window off?
From what I gathered from your install, you just undid some of the screws on that piece in the back, and stuffed the wire in there with a credit card.
Also, How did you route it to the back? Did you use the floor, or the roof?
Old Mar 11, 2008 | 12:35 PM
4Runner202020's Avatar
mine is ran threw the side of the ceiling to the ribber guard abone the back hatch and mounted just on top of the car back there. works great.
Old Mar 11, 2008 | 12:42 PM
isaac338's Avatar
mine's mounted on the hood and runs through a grommet in the firewall to my deck. nice and easy, no wires running through the rig, it's all kept under the dash. make sure the little rubber feet are intact, the hard bottom of the antenna will scratch like a madman.
Old Mar 11, 2008 | 12:46 PM
stormin94's Avatar
most people do.
Old Mar 11, 2008 | 12:48 PM
stormin94's Avatar
Any pics of what the antenna looks like on your hood?
Old Mar 11, 2008 | 12:54 PM
My antenna runs on the floor (down the side) with all the other factory wiring. It follows the factory wiring all the way to the back.
Don't remove the plastic piece around the window, just push the antenna wire in with a credit card.
Old Mar 11, 2008 | 01:11 PM
stormin94's Avatar
I'm not quite getting how you did that... Do you have any pics of where you put the wire?
Old Mar 11, 2008 | 01:49 PM
I took off the plastic trim along the door sills, front and back door, and then lifted up the carpet and ran the antenna cable.
Old Mar 11, 2008 | 02:38 PM
24Runna's Avatar
Currently mine is in the windshield, next to my I-pass. There should be a pic on photobucket. BRB
Old Mar 11, 2008 | 11:14 PM
stormin94's Avatar
Thanks for all the replys!!! I installed the tuner today, and I did a write up on the install:
https://www.yotatech.com/forums/f123...arning-139807/
kawazx636
Oct 6, 2021 03:03 PM
mct75
Aug 22, 2016 01:24 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
ctheiss
Sep 14, 2015 12:18 PM
