motor bogging
Old Jan 9, 2008 | 03:15 PM
cEElint's Avatar
motor bogging
alright.. when i try and pass someone or give it more gas the motor feels dead and then out of nowhere the power kicks in.. like its bogging for a minute, then BAM.. i take off.. haha.. not really sure how else to describe it..
i thought the plugs might have been misfiring but i changed them and it still does it.. another thought was the fuel pressure may be to high?? i'm new to the 22r-e ... used to Hondas.. so any help appreciated
Old Jan 9, 2008 | 03:40 PM
Jay351's Avatar
Have you done a tune up recently? Plugs you have already done ( gapped properly?) I would do cap, rotor and new wires. It sound like you have a hesitation. What RPM range does this happen in? What gear usually?
Old Jan 9, 2008 | 03:48 PM
cEElint's Avatar
i dont have an rpm gauge so i'm not sure what rpm its doing it at.. i'll replace the cap/rotor, wires also and see how it runs then
Old Jan 9, 2008 | 05:59 PM
00SR5HIGHLANDER's Avatar
I'm thinking oyur Catalytic Converter is clogged...Is your check engine light on?
My 00 4Runner is doing the same thing right now, I'm gonna change the Converter since I've had it laying around for a while anyway.
Old Jan 9, 2008 | 06:09 PM
cEElint's Avatar
no, its not clogged.. no CEL.. when i bought the truck a month or so ago the guy just had it smogged and it passed w/ no problem.. i doubt the cat could get clogged within 2 months.. i hardly drive also
Old Jan 9, 2008 | 06:18 PM
bwhyit's Avatar
A clogged CAT would cause a hesitation at higher RPM not "tip in".
I guess I should say it would cause hesitation at higher RPM ALSO not JUST at "tip in".
Old Jan 9, 2008 | 08:13 PM
cEElint's Avatar
yea... it runs fine most of the time but at times it'll bog down.. i went and bought the stuff for the tuneup tonight.. gonna change it in the morning, will report back afterwards
Old Jan 10, 2008 | 10:31 AM
cEElint's Avatar
well, changed that stuff out this morning and made a run to the bank and some other errands .. definitely made a difference.. runs much stronger
Old Jan 28, 2008 | 01:51 AM
ddiablo's Avatar
clean the injectors that solved my trucks problem, it would stall all by itself at a light. it scared me i thought something broke like a cam because of the bang it gave when i started it but it was only a back-fire.
alimant100
Jan 20, 2016 05:58 PM
Yota.Jay
Oct 24, 2015 08:41 AM
Flossy
Aug 5, 2015 05:14 PM
87toyy
Aug 4, 2015 04:51 PM
