master cylinder dry?
Old Apr 22, 2006 | 07:40 PM
KevyWevy's Avatar
is it bad to let the master cylinder resevoir go dry? i've heard conflicting things. if so, why?
im replacing brake pads and probably a caliper (i think its siezed AGAIN) and we bent the hard line a little too much apparently, so now its leaking. can't really figure out a way to plug it, so is it bad for it to go dry?
and why do my calipers keep seizing/
Old Apr 22, 2006 | 07:59 PM
surf4runner's Avatar
running dry will allow air into the lines and the hydraulics fail, thats why its bad.
if your replacing these parts it shouldn't be a problem if you bleed the air out after the repair. dont drive it leaking or youll have a new set of problems.
use the proper grease and lube the calipers.
Old Apr 22, 2006 | 08:17 PM
KevyWevy's Avatar
well thats the thing. as long as i bleed it really well, it will be fine right? don't worry im not driving it.
Old Apr 22, 2006 | 08:31 PM
AH64ID's Avatar
Mine has gone dry several times when doing work.... I refill it and bleed and have never had a problem..
Old Apr 23, 2006 | 12:11 PM
kyle_22r's Avatar
the problem with letting it go dry is that the air bubble that gets in there often needs to be re-bench bled to get it out.
4.34runner88
Feb 7, 2016 02:24 AM
Hugh_Mann
Sep 16, 2015 03:59 AM
old87yota
Sep 9, 2015 12:39 PM
Squigglez
Sep 4, 2015 07:33 AM
