R load rated vs D or E rating ???
Old Apr 22, 2006 | 07:06 AM
nrgetic99's Avatar
If I a looking at A/T tires for 85% on road and 15% offroad use, what are the disadvantages of running regular R rated vs an 8 ply D or 10 ply E rated tire.
The 8 plys run so much rougher on the road but I am guessing sidewalls are stronger.
What say you ???
David
Old Apr 22, 2006 | 08:16 AM
AH64ID's Avatar
What do you mean by R rated tires? like 35x12.50R15... R means radial!!! The ply rating are B (4), C (6), D (8), E (10). Most stock tires these days are a load range B. I use load range C tires offroad, on a toyota I find that to be plenty, and knock on wood, have never had problems. My street tires are an 8 ply, but thats because I run 285's and thats all they come in.
Also with radial tires the plys is a rating. Radial tires dont need the plys like bias ply did.
Old Apr 22, 2006 | 02:37 PM
nrgetic99's Avatar
I meant a straight P metric that quotes wear rating plus traction etc.
e.g 265/75 with 500AB
vs 265/75RR16 D or E etc.
David
Old Apr 22, 2006 | 02:58 PM
AH64ID's Avatar
Gotcha.... P as in P235/75R15 is a 4ply rating. LT235/75R15 will proablly be a 6ply rating. I dont used anything on the trail with a P rating. Any LT will suffice, but you probally wont need more than 6ply rating tires.
Old Apr 22, 2006 | 06:09 PM
CoedNaked's Avatar
Get a C rated (LT usually, before the numbers) for your rig. I doubt you'll notice the difference between a LT/C rated tire and a P rated tire. Considering you do some offroading too, it's worth the very very very minor difference.
Old Apr 23, 2006 | 02:01 AM
X-AWDriver's Avatar
My Nittos are D rated and are still fne on road and didn't even effecy my MPGs going from a C load tire.
Old Apr 23, 2006 | 10:45 AM
terryjmatthew's Avatar
Tires that do not have an expressed load designation are known as Standard Load (SL).
Old Apr 24, 2006 | 07:02 AM
nrgetic99's Avatar
Thanks all,
I have driven SL, C rated and D rated tires and I really like the ride of the SL rated. That and the fact the the C rated are typically 25% more expensive.
For the amount of off raod work I will do, C would be ideal but the Nitto's start at D :pat:
David
Old Apr 24, 2006 | 07:06 AM
Localmotion's Avatar
Originally Posted by nrgetic99
Thanks all,
David
yea, I actually think I have the D load ratings.
The price of the Nittos definately went up. I was looking at a 5th for a spare.
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
smilen724
13
Nov 8, 2015 04:11 PM
MichaelKLerner
Oct 27, 2015 07:18 PM
runnermedic
13
Sep 21, 2015 05:20 PM
