Leaf spring tundra sas
Old May 17, 2018 | 02:34 AM
ethan1911's Avatar
I searched and couldn’t find any good info on this so maybe this forum can help. I’m almost done with a sas conversation on my 2006 tundra I’m running 63” Chevy spring on the front and I was told that I really need a pan hard bar on it. Does anyone have any experience with this, I’ve only went on a few short test drives with it so far and I haven’t noticed any issues from not having it.
Old May 17, 2018 | 02:43 AM
ethan1911's Avatar
This is how my front suspension is currently setup (yes I know the spring bolts are loose, I took this pic before it was drivable)
Old May 17, 2018 | 05:35 PM
dropzone's Avatar
Fossilized
Who built the steering link?
Who and why did they said you needed a panhard bar?
you are only running shackles up front correct?
no expert but it seems like a panhard is usually only used on coil spring suspensions though there are kits available to lead spring trucks.
my SAS is fine with out a panhard but my springs are only 47" long so it might be related to your long springs
you might try pirate.
Old May 17, 2018 | 05:47 PM
ethan1911's Avatar
I built the steering link, it’s a solid and doesn’t flex at all if that’s what you were wondering. The truck drives fine as it is but a friend of mine who has built a lot of hiboy fords says he would put a panhard bar on it.
Old May 18, 2018 | 07:05 AM
jakey poo's Avatar
I don't think you need, seems you don't think you need one, tundra drives fine why use one?
Old May 18, 2018 | 02:52 PM
ethan1911's Avatar
Thanks, I’ve never done a sas before and just want to make sure everything is safe and works well.
Old Aug 7, 2018 | 05:45 PM
ethan1911's Avatar
I decided the truck was to tall so I lowered it, added a panhard bar and had to build a new drag link. It drives great now, for the first time since I’ve owned it I can take both hands off the wheel running 75-80mph.
4runner_guy
Jun 20, 2012 04:54 PM
BEATERYOTA93
Oct 17, 2010 10:12 AM
one2high
Apr 5, 2008 01:14 AM
6lug
Dec 12, 2005 04:16 PM
Dan_90SR5
Mar 13, 2004 10:38 AM
