Leaf Spring Hardware?
Old Mar 16, 2007 | 06:35 AM
Yota Tony's Avatar
I need to buy some hardware to finish putting my leafs together.
I need some bolted spring claps/keepers (they bolt together at the top instead of clamping the spring down, will let the springs seperate about an inch).
Plus I need some friction pads for between the leafs.
Anyone know where I can buy this stuff?
Old Mar 16, 2007 | 10:11 AM
4Crawler's Avatar
You can make clamps like that. Take the stock crimped clamps, open them up into a |_| shape then drill a pair of holes in the uprights and use a bolt and length of tubing if needed:
I use graphite paint (Slip Coat) on my leaves and on a few I use some thin discs of UHMW plastic as anti-friction pads, or I re-use the stock pads.
Old Mar 16, 2007 | 11:35 AM
Yota Tony's Avatar
Thanks Roger. I never thought about that.
Maybe it's my eyes but is the keeper bolted to your top spring?
Old Mar 16, 2007 | 11:37 AM
4Crawler's Avatar
Yes it is, that is for an anti-wrap leaf:
http://www.4crawler.com/4x4/4R_suspe...l#Update-part2
Old Mar 16, 2007 | 12:30 PM
CyMoN's Avatar
is it ok to grease in between the leafs?
Old Mar 16, 2007 | 12:54 PM
4Crawler's Avatar
Sure, it works, I use a graphite loaded grease periodically. It'll attract dirt and does need to be reapplied periodically.
Old Mar 21, 2008 | 11:39 AM
Enelson's Avatar
UHMW Rollers or Fairlead Hawse
There is a manufacturer of UHMW located in Maine. You can either Google "Garland Manufacturing" or try this.
http://www.garlandmfg.com/plastics/products.html
Zach_trun
Jan 22, 2020 04:42 PM
voiddweller
53
Feb 1, 2016 05:46 AM
MichaelKLerner
Oct 27, 2015 07:18 PM
sonorn67
Sep 19, 2015 05:39 PM
Jake28296
Sep 16, 2015 06:10 AM
