View Poll Results: How many miles does your rig go between oil changes?
< 3000
9.85%
3000
34.77%
4000
14.62%
5000
25.38%
6000
3.69%
> 6000
15.08%
Multiple Choice Poll. Voters: 650. You may not vote on this poll
How many miles do you go between oil changes?
Old Apr 21, 2006 | 06:39 AM
  #201
X-AWDriver's Avatar
Originally Posted by Koz
I should be able to safely get 50+K miles out of this oil, time (and UOAs) will tell!
Koz
So,you'll change your oil twice in 100k. Yipes!!! Water from condensation and other contaminants will build up to a bad level within 25k and a test will show that no matter what oil you are using but it's your motor.
Old Apr 21, 2006 | 09:03 AM
  #202
Joe's Avatar
Joe
He's using a dual filtration unit and that by-pass filter will take out the nasty stuff, so there should be just small sized particles floating around in the oil, and his engine won't "feel" them. What he'll find happening to his oil around the 20/25K mile mark is the oil will be close to 40 weight oil, as opposed to 30wt. I don't know if Amsoil has found a way to prevent this in their oil or not, as that was the case a while back. It's using the right filter and changing that filter at the right times that keeps your oil suitable for extended use without excessive wear to your engine components. IMHO using the dual filtration system makes the oil a lot friendlier to your engine when using extended drain intervals.
Old Apr 21, 2006 | 09:08 AM
  #203
X-AWDriver's Avatar
Ah,dual filtration would be nice but my piece of mind wouldn't last to 50k but maybe 25k.
Old Apr 22, 2006 | 01:18 PM
  #204
Tanto's Avatar
I change mine every 3000. Although I use synthetics, I'd rather spend more money now and prolong the time until I have to do something major to my engine.
Old Apr 25, 2006 | 08:15 AM
  #205
Koz's Avatar
Koz
Amsoil reformulated the 0w-30 so maybe it will stay in grade longer. I will be sampling the oil every 12.5K miles. Time will tell how long it holds up. Amsoil has just redesigned the bypass filter with the new nano-fiber filtering material that they claim will last 60K miles compared to 25K.
Koz
Old Apr 25, 2006 | 08:34 AM
  #206
4Runner4Christ's Avatar
Koz
Yes. Their previous Amsoil SDF filters were excellent, but their new Ea filter line is awesome. And they now have one for the 3.4L Toyota engine which I will start using at my next filter change...
Old Apr 25, 2006 | 10:38 AM
  #207
Kalvin00's Avatar
I used to change every 3000, but when I did an oil analysis and saw that the oil was almost like new at that interval, I went to 5000.
The sample I did included plenty of short trips, stop/go, and idling, as well, and the oil still had plenty of life left. That was with conventional, too. If you're using synthetic and changing at 3K you're pissing away your money.
Old Apr 25, 2006 | 11:15 AM
  #208
Tanto's Avatar
Good to know.
Old Apr 25, 2006 | 01:24 PM
  #209
ewarnerusa's Avatar
Amsoil Synthetic
Originally Posted by 4Runner4Christ
I use the same oil and change it once per year (I do about 18,000 mi per year). However 1/2 way through the year I change out the Amsoil oil filter and top off the 0W-30. At the end of the year when I drain the oil it looks better than any dino oil I used to change every 2500 or 3000 miles. I have never done a UOA although I have a small sample I keep each year and will probably test it next time, although I am sure it will come back good...
Amsoil synthetic once-a-year change.
ditto, although I use the 5W-30. This past year I put around 15k miles on the truck and it looked better than I remember dino oil looking at 3k. And although the local shop that stocked Amsoil no longer does, I found a guy who runs a surveying business who runs Amsoil products in his fleet and also sells it. I also use the oversize Amsoil filter (SDF34). I bought the truck new in '03 and except for the first two changes (~4000 miles) I have run Amsoil.
Old Apr 25, 2006 | 02:15 PM
  #210
Kalvin00's Avatar
abcde
Old May 1, 2006 | 03:35 PM
  #211
w99t4rweos's Avatar
As the odometer hits 3,000mi it's time to change, This is probably the cheapest form of maintence you can do.
I've own many cars and done this schedule to all of them with conventional oil, and keep them going strong. I use a high quality brand.
Old May 9, 2006 | 06:50 PM
  #212
KLF's Avatar
KLF
I go 5000 in my '87 pickup (22RE, 200K on it now), 7500 miles in my Lexus ES300 (82K on it). I use Amsoil and that is what they recommend. I use OEM cartridge filters. Honestly, even after 7500 miles in my car, I can still hardly see the stuff on the dipstick when I check it, I almost feel guilty draining it out.
Old May 12, 2006 | 09:31 AM
  #213
TheDarkKnight's Avatar
No idea what oil I use.
Whatever brand the oil change place uses. Might be quaker state... Think its a 5w30, but I am not even sure of that.
But every 3000miles, I go to the same shop, religiously.
tdk
Old Jun 13, 2006 | 04:52 PM
  #214
Ringmaster's Avatar
3000 in both my 4Runner and the wifes Camry.
Old Jun 13, 2006 | 05:38 PM
  #215
Elton's Avatar
i dont change my oil just the filter and top it off
Old Jun 14, 2006 | 04:13 PM
  #216
bike4miles's Avatar
I usually push it to about 4000 miles. I always shoot for 3 though.
Old Jun 14, 2006 | 06:41 PM
  #217
frankjake's Avatar
Every vehicle I have ever owned goes 5,000 miles between oil changes unless something unusual happens such as heavy duty off roading.
Every 5,000 miles makes it easy to keep track of when the next change is due and I honestly think changing at 3,000 miles is just a waste of money.
Old Jun 14, 2006 | 06:46 PM
  #218
Elton's Avatar
my 91 4runner had a sticker thats said you can change the oil every 7,000 miles with normal driveing and 3,000 miles with hard driveing so i would say every 5,000 miles is perfect
Old Jul 19, 2006 | 06:06 AM
  #219
elfiero's Avatar
I change the oil in all my cars and trucks every 3000 miles. When they are under warranty, I drive down to the dealer and pay about ten bucks more than it would cost me to do it myself, but then there can never be any oil related warranty "problems". After it's out of warranty, I buy whatever is the cheapest oil on sale! If it meets the SAE specs, what difference does it make what bottle it's in? I'm an ASE master tech and I've overhauled LOTS of engines and I'll say this- engine wear comes from poor maintinence reletive to type of usage, not oil breakdown.
Old Jul 19, 2006 | 06:41 AM
  #220
Nate C's Avatar
I usually got 6-10k miles in between changes but I have gone as long as 15k.
I always use Toyota filters aand whatever oil is at my dealership. I bought my 4Runner new in '97 and I now have 220,000 miles on it... no problems and still running and looking great!
