Horse power and torque for towing
Old 01-20-2007, 11:18 PM
apc
apc's Avatar
Hi,
I am considering a Toyota Sequoia as a tow vehicle for a 21ft travel trailer. In 2004 the 4.7l engine had 240 hp and 315 lb/ft torque. In 2005, the hp is 282, but torque remained at 315 lb/ft.
Would the difference in hp make any difference considering the torque is the same? Any Sequoia owners out there who have driven both or towed with both?
Thanks!
Old 01-20-2007, 11:39 PM
AH64ID's Avatar
The tq was actually bumped to 325 in the 05's. But with the new std hp/tq measuring system its only 273/314. There is no way to tell what the 04 would have been on the new system, but I can imagine the numbers would be lower. As all hp/tq numbers dropped for toyotas, from what I have seen.
The difference isnt much, and the rpm for peak tq is the same. The rpm for peak hp is higher, so I would imagine that your wont notice a huge difference. Thou I would guess on straight cruising you would get better mpg on the newer motor, but thats just a guess. Partially due to the 5spd being introduced with the hp increase.
Personally i would get one of the newer ones with the 5spd auto. That extra gear between 1st and OD will be nice with a trailer in tow. Towing capacities are unchanged.
pyramid
07-30-2015 10:05 AM
vanion2
07-29-2015 06:17 PM
91yotapup
07-27-2015 07:19 AM
Jeffreynmandy
07-18-2015 08:26 AM
colasurdo
07-17-2015 08:28 AM
Quick Reply: Horse power and torque for towing
