Hi Lift mounts for front ARB Bumper??
Old May 18, 2007 | 12:53 PM
yoda-g2's Avatar
Question Hi Lift mounts for front ARB Bumper??
I know I've seen these somewhere, but I can't find them now. I'm having some departure angle issues with my current rear setup and am thinking of moving the Hi Lift to the front bumper when needed.
I know some people just modify CB antenna mounts, but I know I've seen a full machined piece out there designed for this. Any ideas?
Old May 18, 2007 | 01:22 PM
Corey's Avatar
Co-Founder/Administrator
I had one, I sold it to Chris from trdparts4u.
Look on www.4x4connection.com I think that is where I bought mine many years ago.
http://www.4by4connection.com/arbhiljacad.html
It bolted onto either side of the ARB bumper up front.
I just checked my old 4Runner site, I bought it from Central 4WD, but they did not have it on their site back then, so I had the link to 4x4connection instread on my site.
The nice thing about the ARB for the FJ Cruiser is it has holes in it designed to accept the Hi-Lift.
Old May 18, 2007 | 01:28 PM
Mojo_Risin's Avatar
I think he means to store/carry it on the bumper. I think.
john
Old May 18, 2007 | 01:38 PM
Corey's Avatar
Oooops, my bad.
If memory serves me right, 4x4connection or Man-a-fre had those.
I think you had to bolt those on though, here is a better way...
I bet you can use Four Treks Hi-Lift mounts like I have on my stock rack.
I was thinking at one time to pick up an extra set of rings sized for the diameter of the ARB tubing up front.
I talked to owner Luke about it, and he said ti should work.
http://www.fourtreks.com/
You can look through his list of available ring sizes under the section for the Hi-Lift mounts.
http://www.fourtreks.com/hi_lift_rol...nts_1_75_.html
Old May 18, 2007 | 01:56 PM
yoda-g2's Avatar
BINGO! That's the kind of thing I was thinking of. A little more than I wanted to spend, but the bling factor does have a certain appeal to it.
Plus those big nobs could make it removable in a pinch. Is there a way to lock the Hi Lift in place as well? With that bling it may bee too tempting for little punks.
Old May 18, 2007 | 02:05 PM
yoda-g2's Avatar
Hey didn't I buy those "sliders" from you waaaaay back in the day? I think it was when I first joined YT.
Old May 18, 2007 | 02:13 PM
Corey's Avatar
You mean the Smittybilt nerfs?
I think you did if someone else swung by my place and picked them up for you.
Yes, those Fourtrek mounts rock.
The big knobber on them is a plus.
You could drill through the bolt and knob if you wanted too.
Or just put the Hi-Lift on before a run.
I never leave mine on for more than a day.
I put my ax, shovel, and Hi-Lift on the night before a run and it never gets touched.
Old May 21, 2007 | 07:34 AM
yoda-g2's Avatar
Yup, that was my buddy Tim. I thought I recognized them and the background the pic was taken at. I had a '91 SR5 that looked A LOT like yours. I really miss it and always drool over pics of your old rig when I run across them, then I get all nostalgic....
Thanks for the info on the mounts, I think I may go that route. I can leave the jack on the back all locked up in between trips, then toss her on the front when I need some clearance.
Old May 21, 2007 | 07:39 AM
Corey's Avatar
Cool, I think you will dig the Fourtrek mounts, they are a piece of work.
Old May 21, 2007 | 09:41 AM
d0ubledown's Avatar
if your arb has the two mounting tabs on the top bar..you can do what others have done. simply bolt in a couple body lift pucks/blocks or some metal tubing...approx 2 or 3" high, with an extended bolt so you can wingnut the hi lift on there with a washer.
if not, it looks like the clamping brackets are the way to go...
Old May 21, 2007 | 09:45 AM
yoda-g2's Avatar
Ya, unfortunately I only have the "one bracket" model. But that does bring up a good point, I was planning on a CB up there, but if I put that in the back and fab a second bracket, that may be worth looking into.
Thanks!
Old May 21, 2007 | 10:19 AM
Roadrunner's Avatar
I did something similar with my TJM using some clamps and bolts. They're pretty beefy and I've had no problems:
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
nick9455649
Sep 11, 2015 05:10 PM
Sep 4, 2015 09:27 AM
Vargntucson
Jul 4, 2015 12:15 PM
