Help with part identification
Old Apr 24, 2014 | 06:20 PM
Thomas Reynolds's Avatar
Hello,
I'm looking to get rid of my air pump and swap to a different compressor bracket. I ordered one from a dealer and it was wrong. Same year as mine but 22re. The pulley stuck out to far. I need someone to tell me if they have this bracket on their pickup truck and if it's the orginal bracket. If so please post the year and if its a 22r or 22re and even better the VIN so I can order the EXACT one I need. Pictured here is what I need:
You see how the adjusting bolt is facing you? That's the right one.
Old Apr 24, 2014 | 11:47 PM
wyoming9's Avatar
Red face
From what I have seen Toyota used two different style compressors that is why the brackets can be different.
just what is wrong with your bracket other then the bearing and the tensioner being seized .
which you can buy all the parts for.Or you could
just what year engine are you working on most all the VIN have been purged from the system that old.
so maybe your parts people just guessed .
I have that style compressor on my 87 4Runner.
Old Apr 25, 2014 | 05:32 AM
LOL. I didn't say my bracket bearing and tensioner were seized, because they aren't.
My parts people didn't guess, I did.
You see I have a 1990 22R pickup truck. It has a carb and an air pump. My compressor bracket put my compressor high up near the head of my engine and the air pump down below. My air pump is the actual tensioner. On your SUV you have no air pump because you're probably fuel injected. Your compressor sits low like where my air pump currently does and has it's own idler pulley. I want to change styles to yours. My parts source can still pull VIN's. Your bracket will work but one hole will be off because your compressor is slightly different on the 4runner. It would still work for me though.
I ordered a 22re for the same year as my truck but the pulley wouldn't line upsee how it's too far out?)
Have a look at this thread as this is what I want to do:
https://www.yotatech.com/forums/f116...ing-ac-187915/
This one is also informative:
https://www.yotatech.com/forums/f115...racket-237826/
Old Apr 25, 2014 | 01:40 PM
wyoming9's Avatar
Red face
So the picture is not from your truck.
If you want I can look I might have a bracket and tensionor
Old Apr 30, 2014 | 10:13 AM
Yes please let me know!
Old Aug 3, 2014 | 06:01 PM
I still need this bracket. I have found out what I need though finally. 1986 PICKUP (not 4runner) Federal spec (not CALIFORNIA) 22RE Bracket.
Pics:
Somebody out there has to have one for sale!
Old Aug 17, 2014 | 02:16 PM
Correction this bracket did not work! It's close. The top left bolt hole is not offset like mine. I believe what I need is from a 4runner and looks like this:
th_7-9-11015.jpg?t=1310230227
Notice it doesn't have those two triangular holes in the center. ANYONE out there know for sure what this come from?
Old Aug 18, 2014 | 02:07 PM
wyoming9's Avatar
Red face
I am sorry I Think I forgot all about it unless I sent you a PM.
You might end up having to change a few of the pulleys to get everything to line up.
Old Aug 25, 2014 | 04:44 PM
Yeah well I got the right bracket but it still didn't work because the crank pulley was a 1/4 inch off as I have a late model compressor. Oh well. Selling both brackets in the classifieds soon.
Old Aug 27, 2014 | 06:36 PM
glockluke's Avatar
Does anyone know if they make a swivel water neck for a 20r?
Old Aug 28, 2014 | 05:56 AM
Please start a new thread Glockluke.
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
jakebarrett
Jul 10, 2015 07:15 PM
