Gauge Selection
Old Dec 10, 2006 | 03:14 AM
AH64ID's Avatar
Gauge Selection
I am looking at what gauges to put in my truck when I get it in the spring and want some input. I already know I am going to get a 3 pod apillar mount and run trans temp, oil psi, and air pressure. I plan to get a scangauge II down the road so wont need two voltmeters.
I really like the look of the Auto-Meter Ultra-Lite Gauges... but I have been looking at some ISSPRO ones. The thing about ISSPRO is I can get 270 degree sweep gauges, where as the Auto-Meter are only 90 degree.
For those of you that have gauges what do you have and how do you like it? Maybe I am being too anal, but I would think that the info on a 270 degree sweep would be more informative than a 90 degree....
Then there is also the digital option, and I wouldnt have to worry about sweep.. but the Tacoma dash inst digital, not sure how they would mix... The other advantage to digital is the trans can be 0-400 vs 100-250.. I am not worried about the high temp as those are fatal temps, but low temps are nice to know on warmup....
Any input is appreciated...
ISSPRO has a trans temp one, just no photo of it
Old Dec 10, 2006 | 04:54 AM
ewong's Avatar
autometer DOES make 270 degree elec guages.. check the full line catalog...
Old Dec 10, 2006 | 04:57 AM
AH64ID's Avatar
I did.. nothing that meets all of what I am looking for... I want all 3 gauges to match... so far I cant find that with autometer... if you can please show me a link....
Old Jun 15, 2007 | 07:29 AM
ewong's Avatar
Air Pressure???
Trans Temp
Oil Pressure
Air Pressure
270 sweep (mech or elec)
ok - Autometer Sport Comp series
Air pressure
http://www.autometer.com/cat_gaugede...earch&gid=2838
Mech
Oil Pressure
http://www.autometer.com/cat_gaugede...earch&gid=2879
Mech - run braided steel line. Trust me on this. Or you will be doing it over.
Trans Temp
http://www.autometer.com/cat_gaugede...earch&gid=2889
Mech - bourdon gas tube.
If you want trans temp in elec full sweep - SportComp II series
http://www.autometer.com/cat_gaugede...earch&gid=3539
Looks alot like SportComp so the guages "match"
Old Jun 15, 2007 | 02:43 PM
AH64ID's Avatar
I cant find room for the air tanks, so I installed the OBA w/out them. So I am only putting 2 gauges in, trans temp and oil psi.
I am not interested in running mech gauges...
I decieded to go with the ISSPRO EV gauges, a bit of $$, but probably some of the most accurate on the market, and 270* sweep with elec senders.
I got a red needle,but same gauge
this is the oil version, but they dont have an online photo of the trans
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
