Fuel pump bad?
Old Sep 16, 2009 | 04:35 PM
toybota's Avatar
Fuel pump bad?
I was wondering if any of you out there can help me determine if my fuel pump is bad. I thought it was the efi relay. I swapped it with the starter relay because they looked the same. It started for a second but now it is bad again. I swap them back around and it tried to crank so I know the relays are good. I then shot starter fluid in the throttle body and it started. So that also points to the fuel pump. I then took off the return line and no fuel came out. So I suspect the pump is bad, it does have 200,000miles on it and I run the tank low often. Any pointers would be greatly appreciated.
~Derek
Old Sep 16, 2009 | 07:14 PM
myyota's Avatar
How do you expect us to help you if you don`t tell us what vehicle you have and what engine it has ?.
Old Sep 16, 2009 | 07:59 PM
4Crawler's Avatar
Since you mention the EFI relay, you likely have EFI (22RE or V6), so try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Kluch8651
Jul 9, 2015 10:39 AM
