Front Driveshaft
Old Jul 21, 2008 | 08:56 AM
83's Avatar
83
Front Driveshaft
I've been told my front driveshaft has a binding spot and needs to be rebuilt. I feel like I used to know this stuff back when I had my last Toyota....but it's faded...When I'm not using 4wd, is the front driveshaft turning? Right now I just want to get this truck running so I can sell my car. It's going to be my DD. I'll need 4wd in the winter, maybe sooner if I take the truck out on some trails, but I'm just wondering if the front shaft is something that can wait, or if it needs to be done right away. Rebuild is expensive..
Old Jul 21, 2008 | 08:57 AM
dirtoyboy's Avatar
shaft only turns in 4wd....you can always pull the shaft and run 2wd til you can afford the work
Old Jul 21, 2008 | 10:38 AM
83's Avatar
83
Thank you again!
Old Jul 21, 2008 | 11:00 AM
85toy's Avatar
make sure you hubs are unlocked.
Old Jul 21, 2008 | 11:05 AM
dirtoyboy's Avatar
Whats wrong with your shaft?
bad u-joint?
Old Jul 21, 2008 | 01:45 PM
83's Avatar
83
Ok.
I actually don't know what's wrong with it.....when I bought the truck I brought it in to a local "Toyota's Only" shop and they printed me out a list, in order of priority, of what was wrong with it. One item was "front driveshaft has a binding spot, needs rebuild" or something very similar to that. That's really all I know. I'm just going down the list...
Old Jul 24, 2008 | 09:09 PM
anotherjeff's Avatar
could it be, "front driveshaft has a binding spot, needs lubrication..."
Old Jul 24, 2008 | 09:27 PM
4Crawler's Avatar
Originally Posted by 83
Ok.
Check it out yourself. How? Lay underneath the front end and turn the front shaft by hand (t-case in 2H and front hubs unlocked). Should be able to feel it it is binding. If so, see if you can isolate where the binding is occurring.
Old Jul 25, 2008 | 06:12 AM
83's Avatar
83
Ok. Isolate it and..............?
I'm guessing if all it needed was lubrication the mechanic would have said so, he doesn't do the rebuilding and he's a good mechanic so it's not like he's trying to make extra money off me.
Thanks!
Old Jul 25, 2008 | 06:19 AM
4Crawler's Avatar
Isolate the source of the binding, if it does exist, and then fix it. How to isolate the problem? Unbolt the driveshaft and run each joint through it's range of motion and feel for any binding, grittiness or slop and if found, that is likely the cause of the problem. Might be a u-joint gone bad, easy enough to replace. Might be the CV joint, a little harder to repair.
Old Jul 25, 2008 | 07:58 AM
83's Avatar
83
Ok, thank you.
Old Jul 25, 2008 | 02:24 PM
The hardcore details @
http://personal.utulsa.edu/~nathan-b.../3propelle.pdf
If needed, all of the U-joints, including the Double Carden, are available at the usual outlets (PartsAmerika, 'Zone, NAPPY...). A big vice will help. A press more so.
Once it's out, do it at your leisure. The money you save by doing it yourself can be spent on tools!
88sasturbotoy
Jan 30, 2026 01:57 PM
gillesdetrail
Aug 3, 2015 04:43 PM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
