Exhaust guru's enter...22re lc header restore.
Old Nov 13, 2012 | 05:05 PM
HighLux's Avatar
Got my used super cheap LC header today.
Have a few questions.
PO cut of collector flange. Anyone know what size etc..to have welded on?
Also...it was on an air injection engine. I plan on using LC's block off plate kit as mine is an 87 with no air injection. Correct?
Looks like the plates have pinched off ait tubes on there now.
Lastly...how would you guys clean these up and paint them....I was thinking wire wheel and some kinda high temp paint. Suggestions?
Thanks in advance. I only got $125 in them. Also plan on header stud kit too.
Old Nov 14, 2012 | 12:56 PM
HighLux's Avatar
Ok. Called LC today and they are sending me the flange I need to get welded on. While I was at it...a gasket kit...air injection block off plates...and a header stud kit.
Did some research on header paint and such. Im not gonna blow the cash to
get it ceramic coated. I suppose Ill go the vht flameproof paint and figure out a way to cure it. No way wife will let me use stove. Its brand new.
Old Nov 14, 2012 | 03:01 PM
HighLux's Avatar
Took a wire cup attachement on an air tool and did some cleaning.
Got some more to do...but should clean up nice.
Old Nov 17, 2012 | 03:58 PM
mightymouse's Avatar
looks good man.
Old Nov 18, 2012 | 01:35 PM
HighLux's Avatar
Finished getting the header totally cleaned up. Took the wire cup and some creative sandpaper techniques. But I got it stripped down. Washed it with some soap and water, then wiped it down with acetone.
I used the vht "flameproof" paint. I did a light coat...then heated it up with a torch. I did 4 coats...heating the header up between coats. I got it hot.
I was able to get the torch pretty close to the header with no ill effects.
I mean smoking hot.
Very tough finish. I think it will hold up decent.
Pics...
Old Nov 18, 2012 | 01:36 PM
HighLux's Avatar
alexcarey
Oct 14, 2015 06:05 PM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
toyotasaurus
Sep 24, 2015 03:30 PM
