Doomist's leaks
Old Apr 10, 2007 | 12:35 AM
Doomist's Avatar
Doomist's leaks
I have a leak and its a pretty good leak, dad thinks it might be the brakes brother thinks its a seal. so what do you think! any helpfull suggestions?!
yummy!!!
Old Apr 10, 2007 | 12:40 AM
ChickenLover's Avatar
Stick yer tongue on it.. Does it taste like brake fluid, or diff fluid?
Old Apr 10, 2007 | 01:03 AM
jct61765's Avatar
Take the tire off.
Old Apr 10, 2007 | 01:06 AM
Doomist's Avatar
... when i dont have a garage or a shop... and a jack for that matter. its kind of hard. but i guess i can try! its going to be. Rain+hi-lift+mud=taking tire off
Old Apr 10, 2007 | 01:07 AM
Elton's Avatar
x2 lol
Old Apr 10, 2007 | 01:12 AM
Tofer's Avatar
Sponsor
thank you elton... your input means so much here on YT....
Old Apr 10, 2007 | 01:41 AM
Tofer's Avatar
Sponsor
that so funny will someone please add that to their sig!
Old Apr 10, 2007 | 01:50 AM
Doomist's Avatar
done.
Old Apr 10, 2007 | 05:04 AM
breknraj's Avatar
Don't forget a jack stand! They are pretty cheap, but great insurance for safety!
As to your problem - With the amount of fluid you have, my first guess would be the axle seal. There is definitely enough there to just get a smear on your fingertip, then give it a sniff. Gear oil has a very distinct (and nasty) odor to it, and you will be able to smell it, even with just a little on your finger.
Brake fluid will give you the immediate feeling of drying your skin when you touch it.
Do that simple test (you don't even have to jack it up), then start making your plans from there.
Old Apr 10, 2007 | 06:31 AM
mt_goat's Avatar
Probably gear oil, if all that was brake fluid your reservoir would be about empty by now and you'd be stopping very slowly.
Old Apr 10, 2007 | 06:37 AM
PoleVaulter95's Avatar
i would vote for it being a bad seal because ive been in the same position. but regardless of what it is your going to have to put on new shoes becuase they have been soaking in that oil. be prepared to thouroughly (sp*) clean out the inside of that drum so your braking wont be altered.
Old Apr 10, 2007 | 06:43 AM
techno's Avatar
While you are trouble shooting your problem, (touching, licking, smelling) I had the same issue once. Turned out to be from a dog taking a leak on my wheel....
...and yeah, most likely an axle seal.
86SR522REEFI's Avatar
Check your brake fluid level, is it low? Do the smell check. Is your brake pedal spongy? My truck was that bad when my wheel cylinder went. Good luck. O yea, make your way down to sears and get a floor jack and a jack stand set
Old Apr 10, 2007 | 07:20 AM
Rcross's Avatar
If it was gear oil you should be able to smell it just getting around 20 ft of your truck......
Old Apr 10, 2007 | 11:48 AM
WSUWESTON's Avatar
I vote for the dog piss
Old Apr 10, 2007 | 09:35 PM
Doomist's Avatar
thats kind of weird. the day i found this leak, i was at a freinds boat.. and a dog... took a leak on my tire! !!. thats scarey.
Old Apr 10, 2007 | 09:37 PM
so did u smell it yet
Old Apr 10, 2007 | 09:45 PM
msw0085's Avatar
Originally Posted by Elton
x2 lol
sorry, i have one more post till 2000
Old Apr 10, 2007 | 11:44 PM
Doomist's Avatar
Yea i smelt it, it smells like hydroil oil. (closest thing i could think of) but i opened the diff today, and oil started coming out.. and with a closer look, it has bubbles in it. dont know if thats good or bad. the brake fluid is fine. its at where i filled it last.
Old Apr 10, 2007 | 11:50 PM
Tofer's Avatar
Sponsor
sounds like my suggestion to do the diff breather mod last summer was a good one........ too bad it fell on deaf ears
your diffs full of water... the pressure built up and blew the seal..... thats my call
he's gone
7
Dec 3, 2019 07:08 AM
4runnerjunk
Aug 22, 2015 09:06 AM
accuracy
Aug 4, 2015 08:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
