De-squeaking leafs
Old Nov 12, 2006 | 01:48 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
De-squeaking leafs
My 63" Chevy leaf springs squeak like mad. I have to douse them in silicon lubricant at least one a week so that they dont creak with every tiny movement i make. i think the main culprit is the bushings on both ends. where would i get new bushings and how hard is it to change them out (once the springs are off)? are all bushings the same or do i have to get chevy ones? also, isnt there something i can put between each leaf to prevent bad squeaking? thanks
Old Nov 13, 2006 | 09:03 AM
4Crawler's Avatar
Lots of options, if rubber bushings, pull the bolts and grease with silicone grease or dry graphite lube. Or replace bushings w/ poly bushings (for Chevy springs) and grease bolts w/ regular grease or even install greaseable bolts:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ7
For the leaves, install anti-friction pads on the ends of each leaf (probably need to drill mounting holes), or clean/paint the leaves w/ graphite paint (Slip-Coat brand is what I use) or install some plastic strips (Teflon or UHMW poly) or brush on some graphite grease in between the leaves.
Old Nov 13, 2006 | 03:01 PM
Sonofmayhem's Avatar
Do you consider leaf springs electric?. UNbolt the leafs pull out the bushings. push in the new ones.
Old Nov 13, 2006 | 04:42 PM
Robinhood150's Avatar
Moved to the general section.
Old Nov 13, 2006 | 04:43 PM
i asked so i dont find myself in a situation where im trying to get them out and i cant and then im stuck with my springs out and no practical way to fix them. ill look into those anti-friction pads and such, thanks 4crawler!
Old Mar 30, 2007 | 12:45 PM
do you know where i could get some good strips of either nylon, teflon, or UHMW poly to put between the leafs? what is a good thickness also? would a local place like home depot carry any of that or would it have to be special order? thanks
Old Mar 30, 2007 | 01:09 PM
4Crawler's Avatar
Might be able to get that at an industrial supply place, never looked for it myself.
ktm192k
Oct 1, 2015 08:47 AM
Brodetski
Sep 30, 2015 11:50 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
