clutch
Old May 27, 2008 | 03:15 PM
baseballchamp157's Avatar
clutch
Ummm this sounds stupid but how do you put a clutch in. I have my manual flywheel already on. I have my pilot bushing, clutch disk, TO barring, and pressure plate. I know to put the T/O barring on the forks inside the bellhousing. I know to put the pilot bushing inside flywheel. I also know how to put on the cluth disk and pressure plate. But is that all there is to it? Is it the T/O barring what stops the cluth disk?
Old May 27, 2008 | 03:49 PM
fillsrunner4's Avatar
Pick up a manual. It shall show you and tell you how to install one step by step
Old May 27, 2008 | 04:34 PM
I did and it didnt give good instruction. Im just wounderin if i got it right
Old May 27, 2008 | 04:42 PM
HAVOC's Avatar
Throw out bearing stops the clutch disc from what?
You are using one of these, correct?
Old May 27, 2008 | 04:54 PM
bigt's Avatar
i just did this man...
tob is in the tranny on the fork that connects to your slace cylinder rod...
if you got hte pilot in and the fly wheel one then you put the clutch plate and then the prssure place and put that tool in and tigten..
then with the new tob on the fork raise the tranny back in.. i used a heavy dity ratchet strap connected to the frame under the tranny and a tranny jack...
FINALLY got to try out my welded rear...
doing a clutch is satisfying.. youll get there..
anymore questions p.m me
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
