a/c compressor into air pump
Old Dec 26, 2011 | 04:55 PM
justin_4runner's Avatar
wanted to know if anyone has used the stock a/c compressor into a pump for on board air? and if so how did u do it? i have a 91 4runner that i dont use my a/c and so i was thinking of turning mine into one.
Old Dec 26, 2011 | 07:02 PM
aadown1214's Avatar
Interesting concept, but how would you use the compressor to compress air, when freon is the pumps lubricant as well as refrigerant?
Old Dec 26, 2011 | 07:10 PM
84YotaBuck's Avatar
Do a forum search, plenty of posts about this topic. You would use an in-line oiler. I have a AC compressor I've planned on doing the same thing with for a few years, just never got around to it.
Old Dec 26, 2011 | 07:13 PM
i found a thing on a ford site about people doing it. but i wanted to see if anyone has done thing with a yota.
Old Dec 26, 2011 | 07:16 PM
kdo58's Avatar
pirate has a sticky on their site,under toyota which will tell you every thing you need to know.
http://pirate4x4.com/forum/showthread.php?t=775780
Old Dec 26, 2011 | 07:17 PM
scuba's Avatar
Yes. It's been done. Search "York OBA."
Old Dec 26, 2011 | 07:30 PM
ThatGuy1295's Avatar
Ya I have one.
Very simple. I even put an inline oiler in there, oh and an water/oil separator.
Ya lots of others have done this, tons of info out there. Nothin special is needed, oiler is a perk, prolongs the life of the compressor, but it will work fine without it.
Old Dec 27, 2011 | 03:37 PM
BigBluePile's Avatar
Geezus. It's amazing how nothing is searched any more. Btw, the 3.0 a/c compressors aren't that great.........
Old Dec 27, 2011 | 03:40 PM
think its the same pump as the 4cyl, just different bolt pattern. Had mine for several years with no hiccups. Oiler helps I'm sure. Without it it might have fialed by now.
Old Dec 28, 2011 | 08:39 AM
Volcom's Avatar
I swapped mine to run as an Air compressor. It works well!! I still need to do a writeup on how I did it. I use mine all the time as well as air up buddies rigs on the trail.
Old Dec 28, 2011 | 08:40 AM
Volcom's Avatar
He said stock AC compressor. You have to build custom brackets to make a York work.
MO transplant
Apr 23, 2023 11:58 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
