Bosch Plat. Plugs +4
Old Sep 15, 2008 | 06:31 AM
Robin Veerman's Avatar
Smile Bosch Plat. Plugs +4
My Tacoma is a 2001 4x4 with 405,000kms. It is an awesome truck and I take care of it the best that I can. A few days ago I started hearing a ticking noise from the pass side of the engine. I assumed that it was a stuck lifter. I checked the oil level and added about a cup of oil (Amsoil). Of course no change. I suspected that it might be an injector going bad. However, I had installed Bosch Platinum Plugs about 15,000kms ago, the second set I might add, and so I decided to check them. I started near the noise and it turned out that the middle plug had started to come apart!! The ceramic was loose and the chrome screwcap had come off and it had started to do some blow-by as was evident on the valve cover!! I put a new one in and everything is fine. Phew, I thought that I was in for some expensive internal work!! Anyone else have this type of problem with Bosch Plat plugs?
Thanks, Robin
Old Sep 15, 2008 | 07:04 AM
flatland4runner's Avatar
wow
I'm about 3k into my first set, no problems yet. In fact I thought they are quite good. Will keep you posted
Old Sep 15, 2008 | 02:25 PM
hross14's Avatar
Waste of money .02$--had them and didnt notice anything different about them.
Old Sep 15, 2008 | 02:34 PM
stormin94's Avatar
Congratulations, you've just overspent by about $5 per plug. Those probably won't help your performance at all, esp if they are falling apart.
Old Sep 15, 2008 | 02:47 PM
toy power's Avatar
they are garbage. and so is anything else with more than one electrode, but especially bosch. even the conventional bosch plugs suck. stick with the factory plug and you will get the best performance for the money.
Old Sep 15, 2008 | 04:41 PM
surf4runner's Avatar
i put 40K on a +2 set (the +4 are worthless) w/o issue
i am happier w/ NGK. which is a dual electrode for a 3.4!
Old Sep 15, 2008 | 08:19 PM
Adam F's Avatar
Bosch plugs = crap
Should have done a search
Elton's Avatar
yes bosch and toyota's don't mix
Old Sep 15, 2008 | 08:25 PM
NwRunner's Avatar
NGK or Denso on anything imported. Bosch is bad
Old Sep 15, 2008 | 08:26 PM
Adam F's Avatar
Nor do Hondas. I pulled a broken Bosch out of my mom's Accord once.
Old Sep 18, 2008 | 06:04 PM
brooklee1000's Avatar
Local toyota expert here(in Orangeville, Ontario) recommends factory plugs and wires for best performance. Problem is they cost like $400 for a both. If they don't make any difference, you can't return them.
Old Sep 18, 2008 | 09:00 PM
Jay351's Avatar
Yeah man, throw that bosch crap out. Go get youself a nice set of NGK's. NGK or Denso is all you want to use for ignition stuff on your yota..
Old Nov 16, 2008 | 06:23 AM
Ron Helmuth's Avatar
very helpful
thanks everyone
Old Nov 19, 2008 | 02:14 PM
poorboyota26's Avatar
Bad
Overpriced
Sh t
Change em
Hurry
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
old87yota
Oct 25, 2015 02:15 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
msane99
Jul 17, 2015 10:13 AM
