best timing belt kit for 1997 4runner 3.4L
Old Sep 13, 2017 | 08:32 AM
OscarDixon's Avatar
does the timing belt etc., need to be replaced on my 1997 4runner it has 127000 miles
Old Sep 13, 2017 | 11:57 AM
habanero's Avatar
If it's not been done before (or if you don't know) then yes, it needs to be done. Toyota says every 60,000 for the 97 iirc. It's every 90,000 for newer 3rd gens so I tend to do it some time between. Many of us have had good luck with kits from aircabinman over on Ebay, he has a few to choose from. I personally prefer the ones with mainly Toyota parts, especially for the timing components, water pump and thermostat. Also consider replacing the drive belts and rad hoses since they have to come off to do the job, and if it's time to.
One of his kits:
http://www.ebay.com/itm/15-Piece-3-4...item2a144a37e8
You'll also want to have a torque wrench that can handle 217 ft lbs...
Old Sep 13, 2017 | 12:08 PM
wyoming9's Avatar
Red face
Just be aware he sells like two kits one is all Factory Toyota Parts from Toyota
The other is the same parts from the Original parts vendors
Old Sep 14, 2017 | 07:37 PM
OscarDixon's Avatar
Timing belt kit.....
One of his kits:
Thank you for your input.....aircabinman it is then....
Old Sep 14, 2017 | 07:41 PM
OscarDixon's Avatar
Thank you for your input....aircabinman it is then....
Old Sep 15, 2017 | 05:30 AM
habanero's Avatar
You're welcome and heed what Wyoming9 says too....good advice.
If you don't have a hydraulic tensioner tool and don't want to deal with the original tensioner, also has drive belts:
http://www.ebay.com/itm/15-Piece-3-4...=item2a144a37e
There's a kit without the tensioner as well.
A write-up I like if you want some info:
There's many write-ups and videos to choose from.
and a few piddly notes from my last tb job (I have only done 3 and am not even a shade-tree mechanic) starting post 3102:
https://www.yotatech.com/forums/f200...l#post52360070
There's a couple different torque values for the crankshaft pulley floating around, 184 and 217 ft lbs.
I use 217 ft lbs.
dntsdad
3.4 Swaps
59
Oct 15, 2021 04:17 AM
djohn24
14
Jun 8, 2017 08:56 AM
Jrhendryx
13
May 25, 2017 06:33 PM
