Bent the Bud
Old Jun 15, 2008 | 04:06 PM
wormhole's Avatar
Unhappy Bent the Bud
Well, I learned this weekend how to bend the Bud Built belly skid plate. Now I need to learn how to bend it back. Any ideas??
Front skid and gas tank skid after this weekend:
My 4runner is running naked unerneath until I can find the right hardware to put the factory plates back on(I need to fix some other stuff anyways and it's easier without them on)
Old Jun 15, 2008 | 05:50 PM
Vermejo's Avatar
First off, Congratulations on bending it: meaning you wheel it proper.
Remove the skid and flip it bow side up and circle the affected area like a target. Place the skid over two planks under your truck where you can use a bottle jack to push truck up and skid down. You will have to work the targeted area more than a few times to get things somewhat normal. If you really want it pretty, take it to a metal shop with an industrial press. I almost do this monthly.
Think of the damage you would have sustained w/o it. Better it provides some give as our frames can’t handle what the Bud is served. Any pictures of your truck on the rock that did that?
Old Jun 15, 2008 | 06:21 PM
deserttoy84's Avatar
might want to try one of these...
If it doesnt work get a bigger one!!!
Old Jun 15, 2008 | 06:33 PM
dropzone's Avatar
Fossilized
drive over it on a flat surface. I did that a couple of times with the tailgate on my old '84...
looks like it has been serving it's intended purpose
Old Jun 15, 2008 | 06:34 PM
chrishf12's Avatar
x2 on the press idea
Old Jun 15, 2008 | 07:29 PM
wormhole's Avatar
I'm going to just try and run ove the affected area, just need to find a good spot to do it at. Where it is bent up is right under the transfer case. I would'e hated to see what would've happened if I it that.
This is the best photo that I got of the rocks (also in my Sedona trip report)
Got to fix a few more things now that it is off and stock ones are back on temporarily.
Old Jun 15, 2008 | 07:38 PM
Vermejo's Avatar
Now that’s a trail. I almost guarantee that after your tire passes over the bow it will spring back. I do wish that was the fix though. I’ve had the Idea of using disposable skids made out of industrial cutting boards…
Old Jun 17, 2008 | 12:50 PM
Adam F's Avatar
A torch along with the hammer will make it ALOT easier.
Old Jun 17, 2008 | 01:50 PM
corax's Avatar
x2 on the BFH - it's also a great way to take out aggressions. before I built a flat bed for my previous toy p/u, i had a bunch of friends over and for a 6 pack each they could have at the bed with a sledge
Old Jun 17, 2008 | 02:36 PM
toy_tek's Avatar
Sledge ain't gonna do Jack on Bud.
some drunk guy
Aug 3, 2021 06:09 PM
Zach_trun
Jan 22, 2020 04:42 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
stanz
Oct 30, 2015 10:33 AM
mreagen
Oct 5, 2015 04:27 PM
