Aussie V6 locker is now out
Old Sep 30, 2009 | 12:00 PM
bikerbob's Avatar
Talking Aussie V6 locker is now out
I just saw over on Pirate Ausssie lockers just released their locker for the v6 diffs.
http://www.aussielocker.com/item.php...0/320011/.html
Old Sep 30, 2009 | 12:02 PM
freddy's Avatar
Sweeet!!!
Old Sep 30, 2009 | 08:00 PM
Jay351's Avatar
Holy crap!!! It only took what...6+ years of "in development".
I look forward to hearing reviews vs the lockright
Old Sep 30, 2009 | 09:58 PM
Matt16's Avatar
Wow, I didn't really expect this to happen... ever. That's awesome. Now, I can upgrade to 33" tires without going to a Lock Right.
Old Oct 1, 2009 | 12:00 PM
sweet trav's Avatar
Yippee!!!
Old Oct 1, 2009 | 12:03 PM
vandert's Avatar
Time to buy my rear locker
Old Oct 1, 2009 | 12:16 PM
Adh007's Avatar
I guess they weren't kidding when I emailed them 2 weeks ago.
Sweet.
Old Oct 1, 2009 | 05:45 PM
Stuwy123's Avatar
Wait!!!
I need a 27 spline locker for my pre-96 V6 diff!
Old Oct 1, 2009 | 06:26 PM
tc's Avatar
tc
What axle do you have that's 27 spline? All Toyota 8" diffs are 30 spline.
Old Oct 2, 2009 | 08:34 AM
Stuwy123's Avatar
Whoops, my bad.
It has 27 pinion splines and 30 axle splines.
V6 locker it is.
Old Oct 2, 2009 | 08:51 AM
jrock's Avatar
aussie vs elocker
so for the locker newbeez like myself what the big deal bot the aussies?
why better then e-locker?
Old Oct 2, 2009 | 12:55 PM
tc's Avatar
tc
It's not better than an elocker.
It's the best of the cheapest lockers - check out the locker FAQ in the Offroad Tech section.
Old Oct 2, 2009 | 12:57 PM
Stuwy123's Avatar
An auto-locker like the aussie is supposedly the strongest and quietest auto-locker. It's an inexpensive and reliable modification that will give the best off-road improvement. Hands down.
The factory e-locker swap requires some modification to the housing and are hard to find, especially with the gear ratio you want.
After market e-lockers, cable lockers or air lockers are expensive. They tend to cost more than the entire truck itself.
Old Oct 2, 2009 | 01:05 PM
tc's Avatar
tc
I disagree. The ONLY lockers to not sacrifice either on road drivability or off-road performance are the selectables (ARB or elocker). Yes, you have to pay for that.
The lunchbox lockers are significantly hampered by the weakness of the stock carrier - going to a full carrier replacement (like ARB or Detroit) is a significant diff strength upgrade.
If you want a locker that is pretty drivable on the street, works pretty well offroad, is cheap, and you can install yourself, then Aussie is a good choice.
Some of us want more, and realize we have to pay for it.
Old Oct 3, 2009 | 07:39 PM
Matt16's Avatar
I would say the only "detriment" I've found to having a rear Aussie locker is that I can't lend out my truck to my crappy-driver friends... oh darn eh? Mud tires and removing swaybars are more-invasive modifications for a road-driven IMO.
The Aussie doesn't have the cache' of a ARB, but I wouldn't swap out the Aussie even if I could afford a rear ARB. Up front, I could legitimize the ARB, but in the rear, I think the benefit/cost ratio is low if you're upgrading from a rear Aussie once you figure out the relatively-minor on-road quirks of the locker.
Back to the discussion of the new V6 Aussie, I wonder if it will be much smoother than the Lock-Right. The V6 locker uses the stock spider gears which means the bevel on the locker gear teeth is going to have to match the bevel of the stock side-gears- this means that it will match the bevel of the Lock-Right. As a result, less of the locker can be engineered for smoothness. The side gear bevels were calculated to work well as gears, not to fit some locker.
I wonder...
Old Oct 3, 2009 | 11:00 PM
Stuwy123's Avatar
Originally Posted by Matt16
I would say the only "detriment" ... is that I can't lend out my truck to my crappy-driver friends...
Do you let your buddies "test-drive" your girlfriend?
Nuff said.
I'll be picking up one of these lockers and tossing it in factory 4.88's. Stay tuned for a write-up.
Old Oct 4, 2009 | 12:18 AM
stormin94's Avatar
Here's a question:
Honestly, how would it affect driving, if I like to rally tight corners?
Old Oct 4, 2009 | 02:36 AM
bain's Avatar
Originally Posted by stormin94
Here's a question:
buckle up and hang on
Old Oct 4, 2009 | 04:24 AM
[N8]'s Avatar
Here's a question:
There are several threads in this forum on lunchbox lockers & their quirks that you can research, but if you like ripping around tight corners all of the time, you are probably not going to like an auto-locker with a manual trans. I have front & rear lock-rights and while I love them off road, you do have to change your driving style on the street. Especially if you lift and/or go with larger tires.
6th Gear
19
Dec 10, 2019 07:31 AM
Blizzard
Jan 9, 2007 06:00 AM
Blizzard
Mar 19, 2006 08:41 AM
Renegades
Oct 3, 2005 08:13 AM
io
Jun 30, 2005 09:28 AM
