88 4runner brake problem
Old Sep 22, 2008 | 02:43 PM
Overload2020's Avatar
Exclamation 88 4runner brake problem
ok, I have an 88 4runner, my brakes have no pressure, when i push them all the way down they stop but i have so much play before the brakes kick in, I bleed the brakes so many times and still nothing, no leaks any where, I even changed 1 brake line that looked funny and not damage but just funny looking so i replaced it with a brand new one. what do you think can be a problem?
Old Sep 22, 2008 | 08:10 PM
bigarms23's Avatar
is your master cylinder good or shot
Old Sep 23, 2008 | 03:06 AM
GSGALLANT's Avatar
Does your parking brake hold well without having to pull the handle out too far? If not, it sounds like your rear brakes are out of adjustment. Do a search on here for "adjust rear brakes". It's been covered lots so you should have no problem finding the info on how to adjust it.
To work properly, your front brakes will really not get any pressure until they get feedback from your rear brakes, which won't happen until the shoes start pushing on the drums. If the shoes start too far away from the drums, it takes a deep push of the pedal before the shoes touch the drums.
Old Sep 24, 2008 | 05:04 PM
GSGALLANT I know what you are talking about, well my parking break is great normal operation, i do not have to pull hard and the parking brake cable is new and the rear drums got a new spring kit as well, i kept bleeding all the plugs and no air in the lines, i was thinking of taking my master cyclinder off and see if i can exstend the bar thingy that i think should have a bolt adjustment. if none of that works i will just go ahead and change the master cyclinder and booster.
Old Sep 26, 2008 | 05:22 PM
ok all fixed, I unscrewed the set screw on that rod that comes out of the brake booster to the master cyclinder. and made the brake feel like new.
Old Sep 28, 2008 | 05:36 PM
FredTJ's Avatar
Mmmm, I suspect that the vehicle has a problem.
That set screw should never need adjustment as long as the MC isn't changed out.
Fred
Old Sep 29, 2008 | 08:08 PM
well it works great, in a month i will change the MC and the booster...
Old Oct 6, 2008 | 09:55 PM
poorboyota26's Avatar
had the same problems a couple of months back with my 86. changed out the MC and they went away. took 30 minutes and 40 bucks.
gillesdetrail
Nov 19, 2019 12:56 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
