5 speed trans value
Old Nov 19, 2018 | 08:33 AM
L5wolvesf's Avatar
5 speed trans value
Since I'm going to have to drop my trans (currently the original 4 speed from 1984) I'm considering putting in a 5 speed. Among the things I need to consider are . . .
The cost of a used 5sp trans - plus does it actually increase it's sale value when I sell the truck. What is a "reasonable" price to pay for a used un-rebuilt, 5sp?
Will it really matter, on a strictly street driven truck, which model (aside from a 2x vs. a 4x) of 5sp (W56, L52, G50 etc) I get?
I've read the Ws are the "best" but will that really matter for my situation?
Additional parts such as: a different cross-member (were they different?)
Was the clutch kit different? From searching for clutches already the question whether it was for a 4 or a 5 has not been asked so I presumption at this point is they were not different.
Thank you in advance
Old Nov 20, 2018 | 01:17 AM
ev13wt's Avatar
5 Year Member
You buy a rebuilt from marlin. Clutch must fit on spline count and in diameter to the flywheel. Bellhousing must fit
It will not do anything for any resell value. If it is a low mile, ultra clean truck - it would probably hurt value, as the 5speed "does not belong".
Why would you want a 5th gear? you could also regear your third members (differential). You want RPMs down on the highway, install bigger tires.
Marlins site has a gear speed / vehicle speed calculator - you can play with it and figure out what you need.
Old Nov 20, 2018 | 05:55 AM
millball's Avatar
Many factory 4 speed trucks were built with a relatively high differential ratio so that they are able to run moderate engine speeds on the highway in 4th gear. (1 to 1 direct)
This higher diff gearing makes an overdrive 5 speed tranny less useful, except on fairly level terrain and lightly loaded conditions.
Do you know what your diff ratio is?? I've never seen a 5 speed truck with higher than 4.10s,
Old Nov 21, 2018 | 02:06 PM
L5wolvesf's Avatar
The rear code is G39 which = 3.15 in an 8 inch rear axle. I have no reason to believe the ratio has been changed except . . . when I go up significant hills (like going north out of Phoenix) my engine is screaming in 4th (no tach so just my ear-dyno).
It toned down some once I put some slightly taller (by almost an inch) rear tires on – but it could be better.
Around town I probably wouldn’t use 5th much but between towns and on the highways I imagine it would be useful.
cweich
Jan 24, 2007 05:29 AM
WP
Jul 4, 2006 05:24 PM
Shmukster
May 7, 2006 11:24 AM
kccorvette
Feb 7, 2006 07:51 PM
