22RE Idle Speed Control Valve Test?
Old 11-19-2006, 06:12 PM
pcmentor's Avatar
Can anyone tell me how the ISC works and how to test it. The ohm reading checks out. I am troubleshooting a low idle problem when hot and in gear. have checked the TPS and EGR. What other things can make the idle low?
Old 11-19-2006, 08:08 PM
NCSU-4runner's Avatar
dunno if its anthing like a supra ISC but this is how you do it for a 7M
when i checked mine the movement is VERY subtle, you almost have to have someone else ground the points while you stare at the part that moves
http://www.cygnusx1.net/Supra/Librar...on=FI&Page=107
Old 11-21-2006, 12:43 PM
frty6&2's Avatar
Your MAF sensor could be off, dirty, or broken or you could have a vacum leak, or your timing chain could have jumped a tooth if the chain guide is broken, which they usually are. And I have no idea how the ISC valve works, I just turn the screw till the idle is around 800-900 and roll. Good luck,
Mike
Old 11-26-2006, 03:49 AM
pcmentor's Avatar
The idle somehow is now at a good level. I fixed it some how. Thanks for your input. Pete
Old 05-28-2008, 03:25 AM
pcmentor's Avatar
I'm not having idle speed problems now but I get a miss at 2500rpm. Replaced all tuneup stuff. The O2 sensor voltage is around .19vdc at idle and goes up to .45 at 2500. The O2 also throws a code if left at 2500 rpm for two minutes. Must be lean for some reason. Fixed major vacuum leaks but still low voltage. Any help will be appreciated. Thanks
Charecter1
11-06-2023 10:08 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 22RE Idle Speed Control Valve Test?
