22re with 1-tons
Old Feb 16, 2009 | 06:50 PM
zuknewbie's Avatar
22re with 1-tons
I'm planing on running a 22re, 5spd, dual cases 4.7 in the rear case and 1-ton diffs with a 5.38 gear and 40" tires. My question is what are my chances of street drivability with this setup, don't plan on flying down the highway but wouldn't mind cruising around on a saturday night or something. All opions are appreciated, thanx.
Old Feb 16, 2009 | 07:54 PM
ADH8796's Avatar
Tires might wobble on you but with 5.38 you should be able to push 40's no problem. I run 4.88's and 37's on a 22re and it still pulls strong in 4th going up hills.
Old Feb 16, 2009 | 07:59 PM
tc's Avatar
tc
Not near low enough IMHO - I would be looking at 5.71 or lower.
What axles are you using?
Old Feb 16, 2009 | 08:01 PM
tc's Avatar
tc
But 5th is probably about worthless, and he's gonna have at least 500 lbs on you.
Old Feb 17, 2009 | 04:47 AM
WFO's Avatar
WFO
I dont know what the laws are where you are but around here I could never get away with the tires sticking out as far as they would with tons underneath.
Other than that I think you'd have a nice setup.
Old Feb 17, 2009 | 02:08 PM
zuknewbie's Avatar
thanxs so far, i plan on using a dana 60 up front and corporate14 outback, the biggest matching gear set i can find is a 5.38. As far as laws for tires sticking out were allowed 6"s past the flare, so the flares will be pretty wide as this is all going in a suzuki lj80. Could go with 60's front and rear and go to a better gear but i was hoping to use the 14b i already had.
Old Feb 18, 2009 | 04:33 AM
WFO's Avatar
WFO
Man if you want lower than 5.38 you need to just get some roks
Old Feb 18, 2009 | 04:38 AM
bigt's Avatar
just put landcruiser 80 series axles in the zuk locking front and rear.
or rockwells.. 1 tons just dont float my boat
Old Feb 18, 2009 | 05:34 AM
ADH8796's Avatar
No actually 5th pulls great too until you get to a big hill and then it's a little worthless but I easily pull 75 in 4th (don't know the exsact RPM but it's still fairly low).
Old Mar 13, 2009 | 09:15 AM
Volcom's Avatar
5.89's, 6.16's, or 7.17's would be better but like you said, 5.38's are as low at the 14B is geared. I'm at 5.29's, Toyota axles, and 39.5" Iroks. It's pretty slow on the road
Old Mar 20, 2009 | 04:00 PM
bigarms23's Avatar
if you want to fly down the freeway than change the tires and put on some 35s
Old Mar 21, 2009 | 03:09 PM
zuknewbie's Avatar
Been rethinking the plan and might go with toy axles 5.29s with longfields. Still would like to run the 40s, i'm not hard on the throttle more of a finess type of guy (till i get pissed of sometimes). Any thoughts?
Old Mar 21, 2009 | 07:21 PM
bigarms23's Avatar
if you already have the 1tons than use those
Old Mar 23, 2009 | 03:50 PM
zuknewbie's Avatar
I have the 14bolt but no front axle yet, a good stock front D60 around here easily runs $1000+. Already have toy axles laying around from my old sammy.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
