Sponsored by: CARiD
Will ball joint spacers break?
Old Jan 17, 2011 | 09:27 AM
justin_4runner's Avatar
hey i was looking into lifting my 4runner about 2 to 3 inchs just enough to get 33s under it, might do a body lift later but here's my question. has anyone used the ball joint spacers and spring spacers to lift it? im just worried that they will break on the trail. thanks...
Old Jan 17, 2011 | 09:33 AM
4Crawler's Avatar
The ball joint spacers and associated hardware are pretty strong, see details below:
- http://www.4crawler.com/4x4/ForSale/...onDocument.pdf
Have not heard of any trail-related breakage.
Old Jan 17, 2011 | 09:36 AM
MaK92-4RnR's Avatar
you can actually fit 33s stock. I did.
Old Jan 17, 2011 | 09:38 AM
Swimmerboy2112's Avatar
I have front bj spacers, they are pretty strong, i wouldn't worry about breaking them.
Old Jan 17, 2011 | 09:56 AM
MaK92-4RnR's Avatar
I plan on running some. never heard of them breaking what so ever.
Old Jan 17, 2011 | 10:16 AM
snobdds's Avatar
The ball joint will fail before the spacers will. The spacers are just a pice of milled aluminum, there really isn't anything there to break.
Old Jan 17, 2011 | 10:23 AM
xxxtreme22r's Avatar
I agree either the ball joint itself or the upper control arm will break before that 2"+ piece of billet aluminum will.
Old Jan 17, 2011 | 10:31 AM
bobby_duce's Avatar
there made of t6061 aluminum which is good all around material. people have been running them for years now with little problems. just make sure to read all the write ups to get a good idea of whats involved.
Old Jan 17, 2011 | 10:39 AM
i found a guy in portland area that makes steel 1/2 spaces i was looking at for 60 bucks then paying the 120 for them..
Old Jan 17, 2011 | 10:47 AM
1/2" spacer is not gonna do but rust.
Old Jan 17, 2011 | 11:03 AM
MaK92-4RnR's Avatar
agreed. why go cheap?
Old Jan 17, 2011 | 11:10 AM
bobby_duce's Avatar
this has already been talked about. id spend the extra money and get something thats been tried and tested for years, thats just me though.
Old Jan 28, 2011 | 01:03 AM
daprofessor's Avatar
Those spacers are top shape had them for about 6 years and no problems.
Old Jan 28, 2011 | 08:33 AM
bobby_duce's Avatar
well someone i know talked to this guy on craigslist and my friend was told that he could get 4" of lift with spacers...
Old Jan 28, 2011 | 08:38 AM
im just going to order the ones from ebay for 200. its a 3 inch in the front and 3 in in the rear.
Old Jan 28, 2011 | 08:40 AM
bobby_duce's Avatar
you getting manual hubs?
Old Jan 28, 2011 | 09:27 AM
nope, my add system works just fine for now.
Old Jan 28, 2011 | 10:40 AM
Brenjen's Avatar
Mine have been in use for a couple years & although no extreme abuse I have used them off road & I can't see where they have even picked up a rock ding. So my answer is no, they won't break.
Old Jan 28, 2011 | 11:32 AM
chrishf12's Avatar
I ran my 3 inch bj spacer lift for 3 years and went through at least 5 CV axles because I kept ripping the boots. And this was with manual hubs. Although I did forget to unlock the hubs every now and then.
With ADD and a 3 inch ball joint spacer lift you are going to need a differential drop. If you run this lift you will eat up your CV boots due to the angle and the CV axles rotating all the time (unlike manual where you can unlock the hub from the axle).
Make the investment of Manual Hubs or a Differential Drop if you want 3 inches out of this setup. It will pay for itself!
Old Jan 28, 2011 | 11:34 AM
on the site they had big washer looking things are those for the front differential drop?
