Sponsored by: CARiD
Wheel Spacers
Old Mar 16, 2010 | 06:59 AM
4runnerFireman's Avatar
Wheel Spacers
What wheel spacers are you guys using when putting on 285's vs. 265's?? Looks like it will hit at the top around the upper control arm...Also, I am worried about wear on ball joints and other parts with the lift/spacers??!!
Old Mar 16, 2010 | 07:09 AM
waskillywabbit's Avatar
I think Kregg used 1.25" wide on his 96 that I worked on Sat and he runs 35s.
https://www.yotatech.com/forums/f2/w...eekend-206926/
Old Mar 16, 2010 | 09:18 AM
brian2sun's Avatar
You can get by using these cheapos with 285s:
http://www.wheelersoffroad.com/4runnerwheels.htm
(scroll down to the bottom)
I have 1" spacers and chose those because they are the smallest I could find that aren't the "slip-on" kind. I have heard the slip-ons can vibrate a lot, but they are dirt cheap!
Old Mar 16, 2010 | 10:02 AM
BIC performance's Avatar
I only needed 1/4" for my 285's in the front.
Old Mar 16, 2010 | 11:59 AM
CodyX36's Avatar
Me too. From experience/measuring it has a lot to do with the backspacing and the wheel itself. For instance, the wheel I have w/ 4.25 backspacing may be a little off with another wheel with the same backspacing, just because the wheel is shaped different. I have 1/4" in the front, but since I'm doing my brake upgrade this weekend, I ordered 1.25" bolt on spacers from wabbit. Also depends on a lift if you're going with the 285.
Old Mar 17, 2010 | 01:18 PM
RS964WD's Avatar
spacers
guys i just need to understand one thing....... i got the OME882 for up front, i got the diff drop kit, and OME90004 Shocks, with this lift is it still recommened that i get some wheel spacers? i think the 1/4" would be enough, but i thought i wouldnt need them , could some one clear this up for me???
thanks
Old Mar 17, 2010 | 01:58 PM
brian2sun's Avatar
Whether or not you need wheel spacers depends on what tire size you want to run.
Old Mar 17, 2010 | 02:11 PM
RS964WD's Avatar
Yeah forgot to mention that I will be putting on some 285/75/16AT tires after the lift..... So is the 1/4" spacer necessary??
Old Mar 17, 2010 | 02:29 PM
brian2sun's Avatar
What rims are you running? Because it really depends on the backspacing. If they are stock, most likely you'll need the 1/4"ers, but if they are aftermarket, you may need thicker than that or not need them at all.
Old Mar 17, 2010 | 03:26 PM
RS964WD's Avatar
For now I'm goin to put em on the limited wheels 16x7....
Old Mar 17, 2010 | 03:35 PM
brian2sun's Avatar
I would just get the ones I posted a link to in post #3, they're 5 bucks. It's just like guns - it's better to have em and not need em than to need em and not have em.
Old Mar 18, 2010 | 01:07 PM
yourrealdad's Avatar
So if I can jump in here, I am looking to put a 3" OME lift with a 1" Toytec body on my 98 4runner and run 285/75R16. My wheels are the stock alloy yota wheels (16x7) will the 285's fit with just those 1/4" spacers then?
Thanks
Old Mar 18, 2010 | 04:39 PM
quicksilvr's Avatar
Spoken with true wisdom....
Old Mar 18, 2010 | 06:26 PM
BajaRunner's Avatar
Thanks
Yep. I ran this same setup.
Old Mar 18, 2010 | 08:11 PM
brian2sun's Avatar
Thanks
I have that set up, except my 1" body lift is a 4crawler which was cheaper than the toytec and very good quality. Plus you can get a stock bumper bracket lift so you won't have a gap between the headlights/grill and the bumper (which AFAIK, toytec doesn't offer):
http://www.4crawler.com/4x4/ForSale/...BodyLift.shtml
You don't necessarily need the BL either. With a little plastic fender liner trimming, hammering a couple pinch welds flat and taking my rear mudflaps off, I could clear my 285/75 M/Ts before I put the BL on - and that was with brand new tread. You'll probably have to do that stuff anyways, even with the BL.
punks_is_4x4
Aug 21, 2015 01:35 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
