Sponsored by: CARiD
What's the stock height for a 91 4 Runner
Old Nov 29, 2006 | 10:21 PM
Hitek's Avatar
Smile What's the stock height for a 91 4 Runner
Hi Folks, I’m a newbie here and I been reading a lot on this forum and before I start with my question I would like to thank everyone who has provided all this great information.
Here is my question: I recently purchased a 1991 4 Runner and replaced the saggy rear springs with McQuay-Norris Coil Springs part#RCS255V this raised the rear around 2" taken from the trailer hitch to the ground. I would like to adjust my front end to the factory height.
I did a search but I haven’t found these specs. Can anyone direct me in the right direction? If so please provide how and where to take the measurement from. If you have the rear specs please provide them as well, so I can compare.
Thanks for all the Help
:xmas12:
Old Nov 30, 2006 | 10:14 AM
tc's Avatar
tc
I hate it, because it's hard to do accurately, but the standard dimension for the front is from the top of the rim to the fender opening, and should be about 15" IIRC.
Generally, the front height stays pretty good on these. If you're going to try adjusting the torsion bars, make sure you have replacement adjuster bolts because they frequently break when you turn them.
Old Nov 30, 2006 | 10:30 AM
Elvota's Avatar
I happened to measure mine before mods, but I measured from the ground to lip of fender opening. At the time, the truck had 31" tires.
Front: 35.75"
Rear: 33.5" (I had some sag, but not to bad)
Old Nov 30, 2006 | 06:11 PM
BeaterToyota's Avatar
Yep. My '94 pickup is untouched and sits with 15" between the top of the rims and the bottom of the fenders.
Old Dec 7, 2006 | 04:56 PM
mpavolka's Avatar
With the bigger springs use the torsion bar adjustments and just put it where it looks good as long as it isn't too high.
Old Dec 19, 2006 | 08:44 PM
4Crawler's Avatar
13.5" - 14" rim-fender per this article:
- http://www.off-road.com/toyota/tech/torsion/
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
lledwod
Aug 30, 2016 01:03 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
