What Should I Be Looking For .....
I Just Got A 1994 Singal Cab 4x4 And The Kid Did A Straight Axle Conversion Its A 5 Speed 4 Cyl Efi
Is There Things I Should Be Keeping My Eye Out I Drive It Every Day To Work And I Do A Bit Of Trail Riding It Also Have A 4" Lift
All The Info I Can Get On This Truck Would Be Awsome
And Maybe Some Gearing Info Would Be Nice I Would Like It To Be A Little More High Way Friendly But Still Trail Friendly Is The Stock Gearing Fine?
Also Any Simple Ways To Get The 22 Refi A Lil More Peppy Would Be Cool Advise Also
well, what gearing does it have currently? what size tires???
First things first, do a tune up, that way you know when the last time everything is done, instead of wondering.
Check all the welds and engineering of his sas. Just give it check and make sure you think everything is safe.
What kit did he use for the SAS? High Steer equipped (should be)? Did he use a Toyota axle for the conversion and if so what year? A toyota axle will not have the traditional differential cover on it like a chevy axle, diff bolts will point to the driveshaft.
Post up some pictures (try a free service like photobucket.com) ..watch out for death wobble..
Stock Gearing is usually (probably 4.10) ok up to a 31-32" tire. usual recommendations are 4.88 for 33's and 5.29's for 35's.
landrunner
Aug 5, 2015 09:18 PM
