what happens to the dry gas?
So, I live in Vermont... and it's cold here. last week we saw a couple of days not getting above 0 degrees (yes, fahrenheit for all you canadians). So, my '90 pick up didn't start. Two days ago, after checking all the usual suspects... battery - fully charged, starter turning normally, spark plugs - sparking, i surmised that my fuel line had frozen or my fuel pump had bit it, so I threw in a bottle of Heet (the red bottle). nothing happened. I then jumped in the bed, and shook the truck as much as i could to try and 'swish' the dry gas around... still nothing.
then, this morning with the temps for the first time in a while getting up near 30, she turned right over. obviously was the H2O in the tank/fuel line.
my question is this... if i am going to be putting dry gas all winter long in this beast... what harm (if any) does it do to my engine by burning it. or... does it even burn at all, or does it just sit, unhomogeneously in the bottom of my tank. i dont want to over do it... but this is my winter beater, and she's gotta turn over for me in the coldest of days.... whaddya guys think?
There should not be water in your fuel. If there is, you need to get it out of the system. If that was the case, you put in the heet and run that tank out & fill up again and unless you've got a hole somewhere in your system there should be no more water, problem solved. Problem not solved, then water in your gas was not the problem in the first place. Under normal circumstances there should only be condensation freezing in you tank if you are really low on gas.
The alcohol absorbs water and carries it to the engine to be burned
Im new to the cold but everyone told me that i should keep a fair amount of fuel in my tank because if it gets low that it will freeze. now i was under the impression that the winter mix gas doesnt freeze but im not gonna test it. so maybe you had too little gas in the tank and it froze.? just trying to throw my knowledge into the pot
Because of this there will always be a small amount of water in the tank in winter. Ading 250 ml or so of isopropyl alcohol once a month should keep it to a minimum.
And don't use methanol based gas antifreeze, methanol does not mix with gas and you just get a layer of methanol/water on the bottom of the tank.
Going to a paint store and buying a quart of methyl hydrate for $2 is cheaper than buying gasline antifreeze, and basically is the same thing.
I'm not a fan of running gas that already has ethanol or other alcohol mixed in it due to moisture/water concerns. Who knows if the gas already has lots of water in it?
Blend your own for peace of mind.
he's gone
7
Dec 3, 2019 07:08 AM
