Sponsored by: CARiD
what is the actual name of my tranny?
Old Apr 29, 2010 | 08:44 AM
chinchilla81's Avatar
1981 22r 2wd
it is a 4 speed standard. I want to grab a 5 speed for it. Im relatively new to this forum so ill get some pictures up in a bit.
Old Apr 29, 2010 | 10:45 AM
az4x4runner's Avatar
Welcome to YT, and if it's a 4spd, probably the L45.
Old Apr 29, 2010 | 12:13 PM
mistergarrett's Avatar
it will be listed on the sticker in your door jam.
Old Apr 29, 2010 | 12:22 PM
DeathCougar's Avatar
No
No
Originally Posted by chinchilla81
1981 22r 2wd
It is a W50 being a 2WD, and your trans code is listed under the hood on a plate attached to the firewall. Part of the plate says A/TM, which means Axle/Transmission
Old Apr 29, 2010 | 12:34 PM
xxxtreme22r's Avatar
DC isn't the w50 a 5speed?
I second the L45. that's the one 4x4wire lists as an application for that. but doesn,t separate 2wd from 4wd
Old Apr 29, 2010 | 01:52 PM
Possibly, which would make it a W40 then. According to my computer though, it is a W50. The ID plate will tell it.
4x4wire is specifically for 4x4 vehicles...not 2WD
Old Apr 29, 2010 | 01:56 PM
I take it back, it is indeed a W50
This ID plate is from a 75 hilux. Note the W50 on it
Old Apr 29, 2010 | 02:33 PM
are we trying to determine what he has or what he needs?
Old Apr 29, 2010 | 03:18 PM
What he has I assume. He wants a 5 spd.
Old Apr 29, 2010 | 03:24 PM
Also I still think that being the truck is an 81 it could be the L45. It is a RWD tranny that was used around that period of 81-84 afaik.
Hopefully the OP will check his ID plate.
Old Apr 29, 2010 | 03:43 PM
Hmm, you might be correct, but I have only ever heard of the L45 being a 4x4 here in America at least....
OP! Chime in!
Old Apr 29, 2010 | 07:33 PM
Originally Posted by DeathCougar
OP! Chime in!
Please do. Before we make a 3 page thread discussing what you might have.
AND...
1uzRunner
63
Nov 10, 2018 03:58 PM
Bourbonblues
Dec 15, 2017 05:43 PM
zz_denis
Sep 6, 2015 03:43 PM
eggens
Sep 5, 2015 12:16 AM
Scatterbrain
Sep 3, 2015 06:46 PM
